strange sound when starting engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07runner, Mar 12, 2009.
  1. Mar 12, 2009 at 9:09 AM
    07runner
    07runner [OP] Active Member
    SANTA CLARITA
    07 prerunner trd debadged &black headlights
    debadged, black headlights
    Does anone have any idea what this may be when I start my truck in the morning after it sat all night it makes a grinding noise at the start. It only does it in the morning when it is cold?
  2. Mar 12, 2009 at 11:37 AM
    Zach
    Zach Well-Known Member
    Phoenix, AZ
    08 DC Prerunner SR5
    Window tint...more to come
    If you are referring to after you put it in drive and release the break. This is the ABS activiating. (So i was told by the dealer at the first oil change)
  3. Mar 12, 2009 at 12:25 PM
    07runner
    SANTA CLARITA
    no it does the sound as you start the truck while in park before even getting int drive
  4. Mar 12, 2009 at 12:26 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Sounds like a bad starter
  5. Mar 12, 2009 at 1:03 PM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    If the AC is on and/or the vent is in DeFog setting, then the AC compressor can make an ugly noise on the first start of the day.
    Fritz
  6. Mar 12, 2009 at 1:10 PM
    07runner
    SANTA CLARITA
    thanks for the help guys thats sort of what i thought im going to take it to the dealer so they can check it out im going to leave overnight so they can start it and hear it also
  7. Mar 12, 2009 at 1:30 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    x1 What is the position for your vent selector? The sound it makes it absolutely horrible.
  8. Mar 12, 2009 at 2:07 PM
    07runner
    SANTA CLARITA
    the position for the vent is on the floor one for your feet and the sound is not horrible but it doesnt sound good so i am going to drop it off at the dealership this coming monday
  9. Mar 12, 2009 at 2:12 PM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    Search around on the forum. I saw a thread a couple of days ago about someone having odd noise when starting up cold. Once the truck/engine was warmed a little it went away,
    It turned out to be one of the air intakes where it it fastens to the quarter panel I believe. It was fixed by putting some gasket material and / or just tightening the clamp.
    HTH
