Strange Thrumming at 65 MPH +
Discussion in '2nd Gen. Tacomas (2005-2015)' started by popeyepalmer, Jan 3, 2014.
  1. Jan 3, 2014 at 5:28 AM
    popeyepalmer
    popeyepalmer [OP] New Member
    Godfrey, IL
    2008 Double Cab 4X4
    I have a 2008 that I just bought with 25K miles on it. At 65-70 MPH I hear a vibration or thrumming coming from the front of the vehicle. Nothing is felt just heard. It is equipped with the long front mudguards. Could that be what I am hearing?
  2. Jan 3, 2014 at 5:29 AM
    popeyepalmer
    Godfrey, IL
    2008 Double Cab 4X4
    Is thrumming a word?
  3. Jan 4, 2014 at 5:33 AM
    darektylka
    darektylka Well-Known Member
    Darek
    Chicago
    Taco TRD Sport DCLB 4x4
    is your truck lifted?
  4. Jan 5, 2014 at 8:18 AM
    popeyepalmer
    Godfrey, IL
    2008 Double Cab 4X4
    No my truck is not lifted. No mods at all except running boards which are secure. It has these very long flexable mud guards on it that I suspect are causing this. I guess I could take them off and see what happens.
  5. Jan 5, 2014 at 9:34 AM
    baja820
    baja820 Well-Known Member
    pacific northwest mountains
    '11 SR5 Tacoma V6 6MT 4x4
    any vibration felt through the steering wheel? I would check the steering rack and make sure the wheels are properly balanced.
  6. Jan 5, 2014 at 10:28 AM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    First thing I'd do is rotate the tires, front to back in an X pattern. That moves the fronts to the rears and reverses direction. Drive the truck and listen if the sound has moved, went away, etc. I have a Toyota camry with Michleins that I do not rotate often enuf, when done there is road noise for 5K before it goes way. You said nothing about vibrations thru the steering wheel or seat so I'd say if it is tires, it is directional wear, not balance. By doing this you have eliminated the wheels and tires from the problem, or if the sound moves with the rotation you know you have a tire/wheel problem.
  7. Jan 5, 2014 at 11:23 AM
    DryCreek
    DryCreek Well-Known Member
    Utah
    08 DCLB TRD Sport
    Pioneer AVH-X2600BT Fog Anytime Trailer Plug Relocate (bullaculla) Ride Rite Air Bags OEM Roof Rack Rearview Camera Wet Okole Seat Covers Maxpedition Holster SOS Sliders Washable Cabin Filter Access Bed Cover K&N Drop In Filter Rearview Mirror Relocate (ImMrYo)
    08' with 25k on it....good find!
