street Taco exhaust...
Discussion in 'Street Trucks' started by tooter, Dec 24, 2013.
  1. Dec 30, 2013 at 9:27 AM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    You would think they would think about all around performance. Without proper scavenging that top end aint worth a dime if you have no bottom end to get to it.
    Im hard pressed to see any gains over the stock tubular as I already have the open cat and 1GR muffler. Getting it as a precursor to when I can afford to go URD S/C....
  2. Dec 30, 2013 at 9:48 AM
    tooter
    tooter [OP] play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    From what I've seen and read... I believe Toyota uses the same muffler as well as the same diameter exhaust pipe for both engines. The URD SC looks like a very well thought out design. :thumbsup:
  3. Dec 30, 2013 at 9:50 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    The piping diameter seems to be a tad bit larger then what I originally had. As for the URD kit come to find out it put 248whp down on 31/32" duratracs through the 5spd+tranfer on an extended cab. Should be able to do well above that without all that crap and the header.
  4. Dec 30, 2013 at 2:03 PM
    tooter
    Greg
    Los Angeles
    That might be a difference between the 2005 and 2012 models. Wow... the URD will make a genuine screamer out of your truck for sure. :)
  5. Dec 30, 2013 at 2:05 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    That's the hope. If I can do 280whp on pump I will be totally happy
  6. Dec 31, 2013 at 11:21 PM
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    Me want boost........
  7. Jan 1, 2014 at 5:27 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Me too, needs raise to aquire boost sooner
  8. Jan 1, 2014 at 5:33 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  9. Jan 3, 2014 at 8:43 PM
    tooter
    Greg
    Los Angeles
  10. Jan 7, 2014 at 7:36 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    He's also on 38 swampers.......
  11. Jan 7, 2014 at 7:44 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It looks cool and all but my concern would be some asshat rear ending you and shoving the exhaust hard enough to crack the head compounding the problem of just maybe needing another bumper and/or tailgate. I suppose that issue could happen with any vehicle with tailpipe out the back of it tho. Kudos on the originality............
  12. Jan 7, 2014 at 7:47 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    The exhaust will completely compress and or shear the bolts off the header before ever doing damage to the head. At least if he were hit hard enough that is the way I see the damage/failure happening.
  13. Jan 9, 2014 at 8:17 AM
    tooter
    Greg
    Los Angeles
    That's why no tailpipes are straight. They're designed to crumple. Mine is as crooked as a dog's hind leg. ;)
  14. Jan 9, 2014 at 8:19 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    On top of the fact that the tail pipe is made out of 12-10 gauge material.....
  15. Jan 9, 2014 at 12:50 PM
    #35
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    When i saw the vid with the URD installed I thought the same even though he up the gear slightly and yes he is spinning some heavy ass mofo tires still seemed almost stock like but when he shifted to second seemed like it took forever to get up there mayn I'm real curious on how this would run on a truck with stock tires and header
  16. Jan 9, 2014 at 1:03 PM
    #36
    Phil Dammit
    Your Mom
    Tempe, Arizona
    fast
  17. Jan 9, 2014 at 1:04 PM
    #37
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    I think thats an awesome and unique idea. I like it. :thumbsup:
  18. Jan 9, 2014 at 3:26 PM
    #38
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Exactly what my thought is but I think if anything ill grab the header first and finish my suspension work this djm notch Sucks pretty much 3/4" gap on passenger side and like 1.5" on the driver side dumb design and when I have time relocate UCA
    URD may come later in the year hopefully they make a stage 3 or somethin
  19. Jan 9, 2014 at 3:28 PM
    #39
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Dude just get those adjustable arms guy posted up on with the heims built in. 200 bucks, cant beat that.
  20. Jan 9, 2014 at 8:20 PM
    #40
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    I thought bout that too I just waiting to see his end result before I start buying em all
