Stripped oil drain bolt, what are my options?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by locster, Apr 10, 2015.
  1. Dec 13, 2016 at 4:13 AM
    #41
    topcathr
    topcathr Well-Known Member
    2015 limited
    self tapping drain plug
  2. Dec 13, 2016 at 4:18 AM
    #42
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... Man speaks with with truth & wisdom of 1000 Tibetian Monks. :)
  3. Dec 13, 2016 at 6:50 AM
    #43
    Flannel_Lover
    Flannel_Lover Your resident questionable advice giver
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    Alpine component speakers Rockford Fosgate 10" sub Pioneer DEH-X6800BT Kicker CX 300W amp Extang Trifecta Big Country Brush Guard
    I work at VIOC, when we strip pans we just re tap them, or put in a pan saver.
  4. Dec 13, 2016 at 6:59 AM
    #44
    Rctrumpet1993
    Rctrumpet1993 Member
    2014 red regular cab 4x4
    None
    Who actually strips pans anymore? Normally it's just the plug these days. No way I would pull the pan for something like a stripped thread.
  5. Dec 13, 2016 at 9:53 AM
    #45
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    And this is why people hate you. if you fuck up some bodies car, you need to fix it properly. Not some bandaid, and never tell the customer.
  6. Dec 13, 2016 at 10:16 AM
    #46
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    and a Fumoto valve
  7. Dec 13, 2016 at 10:21 AM
    #47
    stump jumper
    Bill
    Texas
    idiots at the quick change places that over tighten them. My son took his Escape to one once and I had to get out the 2 cheater bar and 5/8" ratchet on the next change. I thought it was stripped for sure. That thing was torqued at least to 80 FTLBs
  8. Dec 13, 2016 at 10:42 AM
    #48
    Rctrumpet1993
    None
    The reason they do that is because they are so afraid the person will leave it loose and they will have to eat an engine. A pan repair is much much cheaper than an engine. If I remember correctly from when I was a tech a Toyota, I believe the spec was 15lbs.
  9. Dec 13, 2016 at 12:05 PM
    #49
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Torque spec for the engine oil drain plug on the 4.0 is 30 lb-ft and the 2.7L is 28 lb-ft. https://www.tacomaworld.com/threads/oil-pan-drain-plug-torque-spec.6754/
    OP glad you got it fixed right with no leaks. Good on you. And thanks for the pics. Everyone makes mistakes as long as we are truly living life and learning, and taking risks... I'm hoping that my massive blunders will get smaller as I get older and (hopefully) wiser :)
  10. Dec 13, 2016 at 12:07 PM
    #50
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Tap it and put a fumoto valve in there
  11. Dec 13, 2016 at 1:13 PM
    #51
    HawkShot99
    Kingston, NY
    All of you people saying to put a Fumotive valve in there....do you have skid plates? I was all set to order one, but when I crawled under and looked at the pan there is no way I'll put one on my truck. it would be sticking straight down a inch or so with no protection. the factory skid stop a foot or so before the pan.
    On other vehicles I have owned the plugs is mounted in the side of the pan, not facing straight down.
    For what a full coverage skid plate costs, I can deal with using a wrench. I don't offroad so need for the skid.
  12. Dec 13, 2016 at 1:17 PM
    #52
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Nope
  13. Dec 14, 2016 at 3:27 AM
    #53
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    I've got the TRD skid because it looks good as I don't wheel heavy at all. The fumoto valve is protected by the cross member. One would have to do some serious damage to hit and dislodge the valve. If I was a rock crawler maybe I would advise against but otherwise they are great.
    spitdog likes this.
  14. Dec 14, 2016 at 4:51 AM
    #54
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    This is what I noticed also when I crawled under and looked at my 2015 when I put a fumoto on my list of things to buy. I guess some of these trucks are different depending on the yr. based on some of these comments.
  15. Dec 14, 2016 at 7:12 AM
    #55
    Flannel_Lover
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    No, I'm afraid your wrong. If I strip a pan I personally come up and apologize to the customer, show them the drain bolt and stripped threads, and then go down to re tap the pan. Using our specialty taps that not only clean out the striped threads but also cut them down to make the new threads. Put the new drain plug and gasket in and flush the pan out with a quart or two of oil. Pansavers are only used if the customer is in a hurry or the pan won't accept the new threads, that almost never happens to me because I know how to do it unlike others that I work with. Next time how about instead of assuming we don't do shit right, ask about our process. :)
    Rctrumpet1993 likes this.
  16. Dec 14, 2016 at 7:14 AM
    #56
    Flannel_Lover
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    What quick change was it? Our torque wrenches that we use bottom side don't even go up to 80 ft. Lbs.
  17. Dec 14, 2016 at 11:48 AM
    #57
    HawkShot99
    Kingston, NY
    You just told me that you do not do the job right. If I bring you a vehicle with a non stripped oil pan I expect that when I pay the "professional" that they don't fuck up my vehicle and do some tap job to "make it right". If you fixed it properly you would install a new non messed up oil pan in the vehicle, but you already said you don't. How is it that all the years of me doing oil changes as a untrained person I have never caused this damage, and I don't even have a torque wrench?
  18. Dec 14, 2016 at 12:44 PM
    #58
    locster
    locster [OP] Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Lol at people saying tap the oil pan for bigger bolt. These pans are stamped sheet metal, not aluminum cast pans. There's no meat left to retap.
    There's a thin, tapped sleeve that is welded on to the pan for the drain bolt. Once it's stripped, it's gone. Plug it with a rubber plug and deal with some oil seeping out, or just replace the whole pan.
    HawkShot99 and Alexely999 like this.
  19. Dec 14, 2016 at 1:36 PM
    #59
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There
    Right here, you can see there is juuuuuust a tad bit of material to go to the very closest next size up.
    phillstill and Alexely999 like this.
  20. Dec 14, 2016 at 2:49 PM
    #60
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not to be a dick, but if you do it right you will never strip a drain plug.
    dlopan, landphil and HawkShot99 like this.
