Strobe Amber & Reverse Lights
Discussion in 'Lighting' started by Nick05Tacoma, Sep 16, 2016.
  1. Sep 16, 2016 at 9:09 PM
    Nick05Tacoma
    Nick05Tacoma [OP] Member
    Nick
    2005 Tacoma Access Cab
    I want to wire 2 amber lightbars and 2 led light pods to a wireless strobe control module while also having the ability to use the 2 led light pods as reverse lights. Could I possibly just tap into the light pod wiring harness and run a switch to control as reverse lights? Maybe theres another way? Links to parts are below. I want to make sure this is possible before purchasing.
    Control Module:
    https://www.amazon.com/dp/B019WSZ9Y...UTF8&colid=W11P1FJX9ZZE&coliid=I1A54MR5IIBG3R
    Led Pods:
    https://www.amazon.com/Nilight-Driv...qid=1474084814&sr=1-1&keywords=led+light+pods
    Amber Light Bars:
    https://www.amazon.com/dp/B00IYUTU8...UTF8&colid=W11P1FJX9ZZE&coliid=I195YOANRT5I32
    Thanks!
  2. Sep 17, 2016 at 9:22 AM
    snowbrdd
    snowbrdd Well-Known Member
    Use diodes on your white LEDs to make sure voltage doesn't feed back the wrong way.
    Nick05Tacoma[OP] likes this.
  3. Sep 17, 2016 at 11:04 AM
    Nick05Tacoma
    Nick
    Would I tap the wiring harness with switch into the white led wiring and put a diode on the lead running into the control module? Also could you post a link to a similar in line diode?
  4. Sep 17, 2016 at 8:17 PM
    snowbrdd
  5. Sep 17, 2016 at 9:30 PM
    caribe makaira
    Caribbean, Puerto Rico
