Strongly considering hood latches
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 23, 2015.
  1. Mar 12, 2018 at 6:04 AM
    #121
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  2. Mar 12, 2018 at 6:05 AM
    #122
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    ChadsPride likes this.
  3. Mar 12, 2018 at 6:06 AM
    #123
    ChadsPride
    Sponsored by TacomaWorld.com
  4. Mar 12, 2018 at 7:46 AM
    #124
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    No need for this but I did notice that my striker on my hood is corroding slightly after hitting the latch over and over. Anybody else noticed this?
    12TRDTacoma[OP] and scottalot like this.
  5. Mar 12, 2018 at 7:48 AM
    #125
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    question, what is a "double access long bed?" over there <---- in your info
    Island Cruiser and scottalot like this.
  6. Mar 12, 2018 at 8:00 AM
    #126
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    LOL I have no idea... Fixed. Thanks Jimbo!
    scottalot and JimboAnz like this.
  7. Mar 12, 2018 at 8:03 AM
    #127
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    :cheers: :rofl:
    scottalot and ChadsPride like this.
  8. Mar 13, 2018 at 8:45 PM
    #128
    pandataco
    pandataco Well-Known Member
    Los Angeles
    2015 DCSB Sport 4x4
    Ever since an incident involving the front of my truck the hood flutters when I get to highway speeds...
    But to be honest the incident(s) occurred so soon after I got the truck that I am not sure if it happened before, I only noticed it on a long drive recently. Kind of scary feels like it might whip up and bust the windshield open.
    Does anyone have a bug visor? My truck came with one installed and I am wondering if the aerodynamic qualities of it cause the rest of the hood to shudder? I am interested in getting those AeroCatch Xtremes but like @ChadsPride I am also afraid to install them... :(
    12TRDTacoma[OP] and ChadsPride like this.
  9. Mar 13, 2018 at 10:01 PM
    #129
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
  10. Mar 13, 2018 at 11:19 PM
    #130
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
  11. Mar 14, 2018 at 2:54 AM
    #131
    smokey_yota
    smokey_yota #FNGFTMFL
    Travis
    Bakersfield
    99 tacoma
    Prinsu Roof Rack Trail Gear Front Bumper Raceline Wheels Toyo AT3 Tires Fiberwerx Fiberglass Fenders And +4" Bedsides HELLA HID Bumper/Ditch Lights Rago Fabrication Ditch Light Brackets Bilstien Front Suspension Energy Suspension Bushings/Sway Bar End Links
    my 2012 has had the same issue with the hood flutter. a few months back it was so bad that i pulled over on i5 here in cali because i was waiting for the hood to fly open lol. everything is tight, latch seems fine. but i will definitely be looking into these now
  12. Mar 14, 2018 at 3:00 AM
    #132
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I have the aerotech ones that the OP originally asked about. Reason why I went this route is I have a glass hood on mine and it was designed to not use the factory latch due to long term fatigue issues the hood would have with fast driving apps. I do like the hood pins as they are a clean and unique looking appearance, but my hood still flutters when I drive although that is likely due to the fact that I have a functional hood scoop.
  13. Mar 14, 2018 at 3:02 AM
    #133
    smokey_yota
    Travis
    Bakersfield
    99 tacoma
    yeah, mine is stock and no scoop. flutters like a mofo around 75ish. everything seems tight :/ will probably order some of these and see if it helps. if not, then i guess its for the looks.. lol
  14. Mar 14, 2018 at 3:28 AM
    #134
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I’m surprised that yours would flutter at that speed. Are there any custom elements or imperfections on your front end? I have a 2012, but when they modeled up my hood they did it based off the earlier 2007 hood which has a bigger hood scoop. Because of this, I don’t think it aerodynamically works as well as the lower scoop that was designed when they made the newer style that mine is. I probably wouldn’t see much flutter though if my hood scoop was a faux one like the factory ones are and didn’t have the cavity.
  15. Mar 14, 2018 at 6:04 AM
    #135
    Sandman614
    Tim
    '06 SR5 Off Road
  16. Mar 14, 2018 at 6:11 AM
    #136
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    My VIS hood, despite latched, flexes and bows with the pressure changes at speed. Just not at the front corners any more.
    Being more flexible than the steel hood, those amplified corner flutters were concerning.
    Mine too has a functional scoop, with added venting slots at the rear, near the windshield cowl.
    Coot83[QUOTED] likes this.
  17. Mar 14, 2018 at 6:18 AM
    #137
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
  18. Mar 14, 2018 at 6:47 AM
    #138
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I’ve only ever noticed my hood fluttering once, top of a bridge on a really windy day going 140kmh.
  19. Mar 14, 2018 at 6:48 AM
    #139
    pandataco
    Los Angeles
    2015 DCSB Sport 4x4
  20. Mar 14, 2018 at 7:33 AM
    #140
    Sandman614
    Tim
    '06 SR5 Off Road
    scottalot and Drainbung like this.
