STRUCTRON SAWTOOTH SHOVEL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sriracha Tacoma, Jun 6, 2017.
  1. Jun 6, 2017 at 4:06 PM
    Sriracha Tacoma
    Sriracha Tacoma [OP] t40fpv
    Hong
    2007 Silver Tacoma 4X4 TRD Access Cab
    3 inch Lift, All Terrain Tires and Rims
    ChadsPride likes this.
  2. Jun 6, 2017 at 4:57 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    :popcorn: Also need wheeling shovel...BUMP
  3. Jun 7, 2017 at 5:02 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  4. Jun 7, 2017 at 7:43 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have several Structron tools, including shovels (but not the one pictured.) I think they are really good shovel. Their round point is the one I carry in the truck when I am off road.
    My shovels are long handled, not D-handled like the one in your picture. I am 6'2", and find D-handles to be too short for my liking.
    The only drawback, if it is one, is the fiberglass handle does not feel like a good, solid wood handle. It is a great handle, but I do miss the feel of a wood handle. (The fiberglass is probably much stronger than wood.)
    EDIT: I see they make the shovel in hardwood. I might be getting a new shovel...
  5. Jun 7, 2017 at 8:30 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    That sawtooth shovel looks to me like it would be garbage for wheeling. I carry a shovel in my truck at all times. I mainly use it to clear fire ring perimeters and dig toilet holes. I'm never worried about roots, I'm worried about rocks. I'm frequently slamming my shovel into the dirt to try and dislodge rocks, get under them and pry them up, often with all my wight on the back of the scoop. You won't get to choose what soil you're digging in but it probably won't be potting soil. I refuse to believe those little teeth won't bend or instantly dull and be a huge pain in the ass.
    Go for a short D handled Razorback with a full size scoop, it's what I carry. Tough as hell, compact enough to carry in the truck at all times, and you can get it at Home Depot.
    stickyTaco likes this.
  6. Jun 7, 2017 at 9:01 AM
    youcantseeme
    youcantseeme Well-Known Member
    E
    Colorado
    2015 SSM Taco TRD
    13 cupholders for beer. All the Weathertechs.
    Something else to consider, as @Scott B. mentioned, is long-handled vs. short-handled. Short-handled shovels are much easier to carry in your truck if you aren't going to mount them in the bed or on a roof rack. However, you may find yourself in situations where short shovels are a PITA to actually use while wheeling. Personally, I've been in several situations where a long-handled shovel would have made things MUCH easier (buddy high-centered on snowpack, for instance). Again, it really comes down to preference, and plenty of guys on here run shorter shovels without issue, but something to consider.
  7. Jun 7, 2017 at 9:44 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    I haven't heard of the two other shovels but they look like good options. One thing I did notice is the Krazy Beaver breaks down for storage, the handle and blade are removable. That's great if you need it but on the other hand it's a single pin connection. If you use your shovel a lot I'd be concerned about that as a wear point. Depends on how much you plan to use it. I have a military compact folding shovel that I've used like 4 times in the last decade, so it's worked out. Since switching to a Tacoma I've added a full size shovel and I think having both will cover my needs.
    I haven't actually seen or held the Krazy Beaver so they might have addressed the concern over the connecting pins but I'd want to check it out.
  8. Jun 7, 2017 at 12:02 PM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    I use a long wood handled shovel in order to reach anything under the truck. The handle and/or shoulder is sometimes used to dislodge out of reach obstructions. Short shovel would have limited uses. I wouldn't want to use a saw tooth shovel close to a tire.
  9. Jun 7, 2017 at 1:17 PM
    toryt
    toryt Active Member
    tory
    Layton Ut
    2014 silver tacoma
    Bilsteins 6112's and rear Dakar leaf springs, BMAF rocker guards, Relentless bed rails
  10. Jun 7, 2017 at 5:04 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I carry a D handle shovel year round, mounted in the bed ($20 at Home Depot) and in the winter when snow may be an issue I also have a backcountry shovel that is easier to use in the snow.
    [​IMG] [​IMG]
  11. Jun 7, 2017 at 5:06 PM
    BrokenMech
    BrokenMech Well-Known Member
    Upstate, NY
    2019 4Runner TRD Pro
    I've use the Gerber Nato folding shovel. Works pretty well and it's compact.
  12. Jun 7, 2017 at 5:07 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    subbed for new gb ideas
    Durdy, Chase8059 and fatfurious2 like this.
  13. Jun 8, 2017 at 5:23 AM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    I'm not sure what brand it is but I've been carrying the same D-handle shovel around in the last two trucks (broke the old one tha lasted the previous 3 trucks). I picked it up at one of the big box stores. Don't over think it, it's a shovel to move dirt. If you are going to do any chopping, get an axe. I carry a 3/4 axe along with the shovel. Of course I live in Florida where we don't have rocks, just sand, lots of deep sand and trees. I've also thrown in a chain saw when there have been storms since some of the trails can have a fallen tree blocking the path. Much easier than chopping with the axe!
    Up north I carried essentially the same thing though and added a snow shovel in winter.
    BrokenMech likes this.
