Strut / Coil Spring / Mount Assembly Brands
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, May 27, 2018.
  1. May 27, 2018 at 7:47 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
  2. May 27, 2018 at 9:51 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Why are you looking to buy it as complete, it’s really simple to assemble them
  3. May 27, 2018 at 1:25 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Moog is junk. I'd sooner find someone's OEM take offs and swap the shock with another Bilstein
    vettehigh[OP] likes this.
  4. May 28, 2018 at 1:36 PM
    vettehigh
    Jon
    Upstate, NY
    Should I go with Bilstein's and new springs (what make?)
  5. May 28, 2018 at 3:14 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Everyone here like the 5100 with some ome 880 or 881.
    Are you looking for stock hight or lifted
  6. May 28, 2018 at 4:11 PM
    vettehigh
    Jon
    Upstate, NY
    stock
  7. May 28, 2018 at 4:14 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Maybe some 4600 and oem or moog coils. I personally have no experience with moog coils but i hear some guys run them with no problems. I personally would go with oem coils
  8. May 30, 2018 at 9:25 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Check your ride height at the front end on level ground with nobody sitting in the truck. If it's within the specs then I wouldn't worry about it.
    To change the shocks you will need a spring compressor. They cost around $55 so you may want to add this into the total price of the change.
    I use Bilstein 4600 shocks all around. A front-end realignment after the work is done wouldn't hurt, either.
  9. May 30, 2018 at 9:33 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You can rent a spring compressor at any local auto shop and it will be cheaper.
    Or there is a way of taking them apart without one just using your trucks weight.
    Or an auto shop should be able to put them together for you
  10. Jun 4, 2018 at 1:09 PM
    vettehigh
    Jon
    Upstate, NY
  11. Jun 4, 2018 at 1:11 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    If you have 700$ to drop i would say go for it, but ask around and see if you can find any guys one here running those and get there feed back
  12. Jun 4, 2018 at 1:13 PM
    vettehigh
    Jon
    Upstate, NY
    A guy who owns a body shop owes me for a shitty bed liner that he did. I will not see the cash back, so I might have him order these instead
    Sperrunner[QUOTED] likes this.
