Stu’s UTE
Discussion in '3rd Gen. Builds (2016-2023)' started by Stopmithering, Jul 26, 2019.
  1. Jul 30, 2019 at 1:59 PM
    Stopmithering
    Stopmithering [OP] Well-Known Member
    Stuart
    17 Tacoma TRD Sport ACLB MT
    Today I put the truck on the ramps and moved the spare tire hoist an inch or so back to make room for future larger tire. FDE86F81-6FF8-4906-8BA0-B9334EE92027.jpg
    While I was under there I extended the diff. breather up into the flatbed headache tube.
    0E334FB7-0871-4383-99DA-CE23857C1CDF.jpgAE603990-D4C2-45B7-A622-0BA2FF63B7D9.jpgB9DBD885-2D2E-47DD-8045-F9C83FC9DD7C.jpg
    Slashaar and Kolunatic like this.
  2. Jul 30, 2019 at 2:03 PM
    Stopmithering
    Stuart
    Also above the spare tire I built a storage shelf for stuff like Tarps, logs , grill etc.. The aluminum shelf was salvaged out of an old ambulance.
    habaneroTrd, Slashaar and Gunshot-6A like this.
  3. Jul 31, 2019 at 10:11 AM
    FortuneFavorstheBruin
    FortuneFavorstheBruin Well-Known Member
    Zack
    Austin, Texas
    2018 Tacoma Off-Road
    Stu I love this build. I’m close (relatively) to the Fourwheelcampers buildings.
    Curious how much the flatbeds go for?
  4. Jul 31, 2019 at 5:48 PM
    Stopmithering
    Stuart
    They start at $27,000. There seems to be a $10,000 premium over the slide in models. I’m not clear quite why that is. I’m guessing, on the slide in, the base is made of wood. On the UTE, I imagine that lower structure is aluminum, so more expensive materials plus welding etc. Also there is more space, so again more materials.
    The real shame is they don’t do a shell model in the UTE. I would have loved to build it out myself.
    Round the world and Gunshot-6A like this.
  5. Aug 3, 2019 at 8:39 PM
    Stopmithering
    Stuart
    I spent the day fabricating brackets for the Viair heavy duty onboard air system, which I am mounting underneath the flatbed.
    The compressor is going to bolt to this platform, which in turn will be bolted to the foremost cross member and the underside of the flatbed. Primer has to dry for 24 hrs before top coat!
  6. Aug 3, 2019 at 8:55 PM
    Stopmithering
    Stuart
    Next to the compressor and above the exhaust will hang the 2.5gallon air tank. I bent some aluminum in the bench vice that will assist in bolting the tank to the underside of the flatbed.
    Slashaar, Nimble9 and 99kx250 like this.
  7. Aug 5, 2019 at 5:18 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
  8. Aug 5, 2019 at 7:46 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Looks good!
    Will the tank bolt to the bed or the frame?
  9. Aug 5, 2019 at 10:13 AM
    Stopmithering
    Stuart
    The tank is going to bolt to the underside of the bed. Initially I was thinking of avoiding that just in case I ever have to take the bed off. In reality I don’t see needing to remove the bed, and it makes the project sooo much easier to use that space to bolt stuff to.
    I got the top coat on the bracket first thing this morning, so hopefully I can start bolting stuff on this afternoon.
    Naveronski[QUOTED] likes this.
  10. Aug 5, 2019 at 10:23 AM
    Stopmithering
    Stuart
  11. Aug 5, 2019 at 11:40 AM
    Stopmithering
    Stuart
    Pulled the grey water tank out for a final tweak. The drain was hanging out a little too far on the passenger side. It’s a tight fit between the bed and the gas tank and I had to soften it up with the heat gun and squash it with the mallet, until it set.
    Now the drain is tucked in a little, I can worry less about it getting snagged on a branch.
  12. Aug 5, 2019 at 4:24 PM
    Stopmithering
    Stuart
    Well that was a royal pain in the arse! A tight fit and really difficult to get to the bolts.
    Now to figure out plumbing and wiring.
  13. Aug 8, 2019 at 1:42 PM
    Stopmithering
    Stuart
    Ran the main power to the auxiliary panel in the engine bay with an 8 gauge wire yesterday. I used some aluminum foil as temporary heat shield as it runs parallel to the exhaust. Will have to look into some thing more long term.
    Today I worked on the cubby mount for the pressure gauge. I modified the dash mount to fit in the cubby.
    I sprayed everything with plasti-dip to try and blend the textures.
    Identified the ignition fuse to tap into for power.
    Unfortunately I’m off to Florida for a week or so. Project on hold.
  14. Aug 8, 2019 at 1:58 PM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    dude this thing is bad ass i want a flatbed so bad for my short bed truck
  15. Aug 16, 2019 at 6:46 AM
    #35
    kite_325
    kite_325 A simple human, being
    North Carolina
    2017 TRDOR
    This is a dream build. :bowdown:
    Stopmithering[OP] likes this.
  16. Aug 23, 2019 at 5:02 PM
    #36
    Stopmithering
    Stuart
    Worked on making the mounts for the air hose quick connects.
    Used cardboard as a template then cut the 1/8 inch aluminum with a worm drive with a beater blade and a jigsaw. Finished the edges with a belt sander and a palm sander.
    I thought I was using primer, but it turned out to be inferno! It helps show where the brackets sit in the photo. But not really the look I’m going for, so I’ll paint them black on the weekend.
  17. Aug 23, 2019 at 8:52 PM
    #37
    edgerat
    edgerat Well-Known Member
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    I kind of like them in Inferno :)
  18. Aug 25, 2019 at 7:11 AM
    #38
    Stopmithering
    Stuart
    I ran an 8 gauge wire up to the battery. At first I tried splicing it to the 12 gauge wire from the pressure switch with solder, but it didn’t seem very clean. Eventually found these step down connectors that solved the problem.
    Also put some extra heat shrink on, just in case.
    Slashaar and edgerat like this.
  19. Aug 25, 2019 at 7:33 PM
    #39
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
  20. Aug 27, 2019 at 2:44 PM
    #40
    Stopmithering
    Stuart
    Ran the wires and hose to the cab this morning.
    I used a dowel with a point on the end to poke a hole through the fire wall gasket. Then fed the hose through from the cab with a little plumbers grease. It was not easy but worked. Once the hose was into engine compartment I had a hard time threading it under the fuse panel and ended up kinking the tube. Luckily I had some spare and managed to cut the kink out of the run. The 14 gauge wire I fished through the fire wall with some stiffer wire. I ran both down behind the driver wheel well and along the chassis to the bed.
    Bolted the quick connect to the brackets I made the other day. Masked them off and sprayed the brackets black.
    Routed the hose under the compressor platform and used 3M tape and zip ties to hold everything for now. I’m not convinced this will hold up to the vibrations, but we’ll see.
    This took all morning!
    And it’s still not ready to go. I want to run the filter into the cab and mount it in the corner near the rear seat belt. This involves removing the rear panel. I can strip out the head rests and do some sound dampening at the same time.
    Also I haven’t figured out how to tap into the dash panel lights to back light the pressure gauge.
    Slashaar, Nimble9 and kite_325 like this.
