Stuck in 4 Wheel Drive Low
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Aug 19, 2022.
  1. Aug 19, 2022 at 3:41 PM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I already put it in reverse - moved it from 4 wheel drive low to 4 wheel drive to 2 wheel drive etc. Any suggestions, links, replies appreciated.
  2. Aug 19, 2022 at 3:44 PM
    Bishop84
    Bishop84 Well-Known Member
    While in neutral, and set in 4lo, keep cycling from 4lo, to 4hi, wait 10 seconds. You need to get the actuator to move.
    TnShooter likes this.
  3. Aug 19, 2022 at 4:01 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Still might need to roll forward and back a bit, when trying to change from 4low to 4hi, make sure you are in neutral.
  4. Aug 19, 2022 at 4:05 PM
    george3
    New Jersey
    Thanks guys - I've tried those moves without success but I'll keep trying
  5. Aug 19, 2022 at 4:12 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  6. Aug 19, 2022 at 4:13 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
  7. Aug 19, 2022 at 5:03 PM
    george3
    New Jersey
  8. Aug 19, 2022 at 5:04 PM
    george3
    New Jersey
  9. Aug 19, 2022 at 5:12 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If it's beeping it may not be seeing the clutch signal, are you fully depressing the clutch when trying to shift out of 4lo?
  10. Aug 20, 2022 at 7:23 AM
    george3
    New Jersey
    Thanks everybody - This is what worked - I put the selector switch in 4 wheel low then with the emergency brake on and the trans in neutral foot on brake - clutch to the floor - turned the key to on - just on did not start the truck - waited 10 plus seconds - turned selector switch from 4 wheel low to 2 wheel high - heard a humming sound - 4 wheel icon still on - just the 4 wheels no designation of high or low - put it in reverse - backed up a little - heard a clunk - icon gone - problem solved. Hope this helps someone. I looked a the post on taking the actuator out and working on the contact points - so glad I didn't have to do that.
  11. Aug 20, 2022 at 7:31 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Make sure the vent hoses on the actuators are connected and not cracked, disconnected or cracked vent lines are one of the main causes of actuator failure.
    Also engage your 4wd regularly to keep everything moving and lubricated.
  12. Aug 20, 2022 at 11:02 AM
    george3
    New Jersey
    Thanks - I'll check vent hoses next oil change.
    Dm93[QUOTED] likes this.
  13. Aug 20, 2022 at 1:07 PM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    Great you got it to work with that method. But how in the world did you figure that out? !
  14. Aug 21, 2022 at 9:17 AM
    george3
    New Jersey
    I hate to admit it but it wasn't on me - I sat in the truck and my Brother-in-Law walked me thru it on the phone - then I wrote it up on TW in case it might help someone else !
  15. Aug 21, 2022 at 10:14 AM
    Stelcom66
    2007 2.7L 5MT 4WD
    Thanks for writing it up! I saved the method in a document for reference. I have the same drivetrain in a 2007.
  16. Aug 21, 2022 at 11:41 AM
    george3
    New Jersey
    Hope it's useful - I'll ask my 8 year old how to save it in a document.
  17. Aug 21, 2022 at 11:45 AM
    Stelcom66
    2007 2.7L 5MT 4WD
    Yep - just ask the kids!
