Stuck transmission pan
Discussion in '1st Gen. Tacomas (1995-2004)' started by dtopgun515, Jun 15, 2012.
  1. Jun 15, 2012 at 4:28 PM
    dtopgun515
    dtopgun515 [OP] Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    I can't get my transmission pan to fall off! All the screws are out and I've hit it as hard as I can with a runner mallet and still won't come off. Any suggestions??
  2. Jun 15, 2012 at 4:29 PM
    dtopgun515
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    Rubber mallet
  3. Jun 17, 2012 at 8:24 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Maybe try a few paint can openers, if u can shove them in the gasket and pull? assuming you have all the bolts out.
  4. Jun 17, 2012 at 11:13 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Be careful you don't bend the pan lip then you will need a new pan in order to get it to seal, if it were me I would use a stiff sharp putty knife and see if I could get it between the case and the pan.
  5. Jun 17, 2012 at 11:37 AM
    Sunner
    Sunner Well-Known Member
    I'd look at a oil pan assembly diagram to make sure you didnt miss any hidden bolts.
  6. Jun 17, 2012 at 12:37 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    YES! Sharp putty knife and hammer always worked for me! I have done several pans that way and none leaked after resealed.
