Stuck Windshield Wiper!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jevansjr15, Feb 22, 2010.
  1. Feb 22, 2010 at 3:47 PM
    Jevansjr15
    Jevansjr15 [OP] Well-Known Member
    Joe
    Baltimore
    18 TRD Sport 4x4 DCLB Cement
    Has anyone else had this problem??
    I went to turn on my wipers today and my drivers side didn't move at all. Needless to say I was pretty pissed. I pulled over and tried to move it manually, and actually thought I fixed it, but Its still stuck!
    Anyone have any tips/tricks for this? Would something like this still be under warranty? I hear the motors are not very cheap!
    Thanks
  2. Feb 22, 2010 at 3:57 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Is the wiper arm still attached to the spline stud on the truck? Maybe the nut holding it down loosened up enough to warrant it useless.
    There is only one windshield wiper motor, so if you're having trouble with just one side dig a little deeper to find the problem.
  3. Feb 22, 2010 at 3:58 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Did you check the nut holding the wiper on? At the base, there's a small black plastic cover. Pop that off and try tightening up the nut. It's made to let the wiper break loose if need be to save the motor I believe.
    I had this happen just about a month ago. Had just a slight amount of snow on the windshield. I hit the wiper, the passenger side was able to push it. The driver side wiper went up a bit and then just stopped. The passenger side wiper even bent the end of the driver side wiper, which was brand new. I was able to bend it back well enough by hand to still be usable though.
    ETA: If I remember correctly the nut is a 14mm.
  4. Feb 22, 2010 at 4:01 PM
    Jevansjr15
    Joe
    Baltimore
    I'll have to look for that nut. Hopefully its that easy to fix.
    Thanks!
  5. Dec 1, 2010 at 2:09 PM
    Priddle
    Priddle And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    Sorry to bump an old thread but I had the exact same problem last evening after a little snow. One wiper wiped and the other only made an offer to move and just stopped. Once I manually cleared the windshield, the wiper moved but you could tell it was not working right. Plus I could move the arm when the wipers were turned off.
    I searched here and found this thread. I tried the solution above with the 14mm socket and discovered the bolt was really loose. Tightened it and works great now. Just remember to position the wiper at the correct resting spot before tightening.
  6. Dec 1, 2010 at 2:10 PM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    yes happens to me all the time. you need to tighten the nut olding the arm.
  7. Jan 14, 2014 at 10:46 AM
    dvdrdclf
    dvdrdclf Well-Known Member
    Colorado
    2010 4x4 TRD Sport AC
    SNOW
    this just happened to me. tightened the nut, seems to work now. thanks TW!!
