stuff sliding around in the bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrdinh, Sep 25, 2010.
  1. Sep 25, 2010 at 12:49 PM
    mrdinh
    mrdinh [OP] Active Member
    TRD SR5
    westin nerf bars and argricover soft roll up bed cover
    with my new taco, the toyota bedliner from toyota moves stuff around...anyone recommend a accessory to have my stuff in the bed stay put?
    i usually don't use the whole bed, and use a bed cover...the stuff slides always to the back of the bed so i have to unroll the cover to get to the stuff....
    what is the recommendation? thanks
  2. Sep 25, 2010 at 1:06 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    I would like to hear some solutions to this as well.
  3. Sep 25, 2010 at 1:20 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    You have the rubber mat from Toyota? I have a thin piece of rubber mat in the back of my truck and i'm amazed at how things don't move around.
  4. Sep 25, 2010 at 1:21 PM
    tacomaprerunner
    tacomaprerunner Dang liberals.
    1995 Ford F350 7.3L PowerStroke Diesel
  5. Sep 25, 2010 at 1:24 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Rubber bed mat....
    There are many different brands for different prices. I have a Protecta Bed Mat. It's 1/4" thick and is AWESOME. I personally only paid $50 for it at my local truck accessories shop.
  6. Sep 25, 2010 at 1:24 PM
    DevL
    DevL Well-Known Member
    Toyota bed mat.
  7. Sep 25, 2010 at 1:26 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  8. Sep 25, 2010 at 1:27 PM
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    I have the same problem. I was thinking of using Rhino Liner on the ribs of the bed to keep stuff from sliding around. The only thing stopping me is I am not sure that it will stick to the bed. Has anyone tried that yet??
  9. Sep 25, 2010 at 1:31 PM
    Jones
    Jones Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
    Cargo bar Just use it in reverse from the pictures or get two. One for the top of the stuff and one for the bottom. I have one and works fine for stuff to not move. I use D-rings for the bigger stuff.
    If your stuff is pretty light, maybe a shower rod that you twist to expand is basically the same just weaker.
    Or maybe this thing, just seems to be overpriced.
    http://toyotapartspeople.com/search...60967926419&year=05&productdesc=Cargo+Divider
  10. Sep 25, 2010 at 1:59 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Super glue??? maybe even super duper glue?
  11. Sep 25, 2010 at 2:04 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    Bed mat
  12. Sep 25, 2010 at 2:06 PM
    andrew
    andrew Well-Known Member
    05 TRD Sport, 4x4- totaled
    OEM bug deflector
    The toyota OEM bed mat I hear is the best. Read around and most people here say the same.
  13. Sep 26, 2010 at 7:00 AM
    mrdinh
    TRD SR5
    good ideas..thanks...
  14. Sep 26, 2010 at 7:57 AM
    vinnyvavoom
    vinnyvavoom Well-Known Member
    CT
    2020 White SR5 4WD DC LB
    of course
    The bed mat was my first addition. It works perfectly.
  15. Nov 6, 2010 at 1:47 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    I fixed that. I haul Drums and Anvil cases all over Texas and I found the best tool. Tractor Supply has "E Track" like you see in cargo trailers and vans. I bought 2- 24" sections and a 10 ft E Track strap. the strap is 2-1/4 " wide and is strong as a tow strap. You just snap in the one side, pull it across your gear and lock in the other side, pull her tight and nothing moves! I used LARGE washers on the box to keep the track from poping loose. SWEET FIX I also added 2 D rings to the front of the box.
  16. Nov 6, 2010 at 2:03 PM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    I went to Tractor Supply Co and bough a roll of no-slip tape (like for stairs and such). Cut it to size and placed it on the raised portion of the bed, on the outer 4 ribs on either side. Stuff in the middle slides, most of the stuff on the tape will stick pretty well.
  17. Nov 6, 2010 at 2:06 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I got stuff that goes in drawers, like above. Cheap and did the job.
