Stuff to check on higher mileage First Gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, Apr 17, 2012.
  1. Apr 17, 2012 at 8:35 PM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Going to look at a couple first gens. Both are the V6, autos, 4x4. They also have 150k+ miles. I know the first gens are suppose to run for 200+, but isn't this nearing their ability. Also, what are things to look for when there are that many miles?
    Or, should I just avoid them since the high mileage?
  2. Apr 17, 2012 at 8:38 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    150k is not that much for a first gen. The engines are cast iron.
    300k is when I would avoid them.
    Edit: Take it to a mechanic, best money you can spend before you buy it.
  3. Apr 18, 2012 at 7:49 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Look for frame rust, timing belt service, leak and etc like engage in 4wd, shifts is gear.
  4. Apr 18, 2012 at 8:00 AM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Yup. They can check it all over, not just the common problem areas.
  5. Apr 18, 2012 at 8:13 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    This is about the time seals begin to fail.
    -Check your water pump seal, differential seals, and transmission seal. The tranny seal is the hardest to replace (you have to drop the tranny) but the others are pretty easy.
    -Check rear leafs, they will be frowning by now and probably would need to be replaced before you tow/haul.
    -Check frame rust.
    -Check spark plugs.
    -Always check oils and fluids (clean/dirty, etc...).
  6. Apr 18, 2012 at 10:40 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    since when is there a set time when seals begin to fail? :confused:
    Its really the luck of the draw. You can have a 200k+ truck with no leaks, or get a rear main seal leak at 100k...
    you never really know.
  7. Apr 18, 2012 at 2:16 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    while taco's can be reliable, there are alot of car/truck that can make it 200K plus as long as proper maintenance was done. I would get carfax on the trucks so you will have a idea where they have been, and how many owners they have had. and if they have had their frame replaced. something to keep in mind. remember when you are buying something used, you are buying something someone else did not want anymore, so don't jump into anything, look for something that someone cared for. and there are lots of things, nothing will last forever, so try to balance what you will have to do to the truck, (tires, radiator,paint, ect) on what you are going to pay for the truck.
    dont get trapped into paying a premium for a truck, and then have to spend alot on it, because keeping the truck running does not increase its real value.
    take a flashlight and look under the truck, see how she cranks up, idles, look for blue or white smoke, stick your finger in the tailpipe and feel around, is it oily or very watery...... and keep your poker face on.
  8. Apr 18, 2012 at 2:48 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    According to First Team Toyota in Chesapeake, their maintenance data has them replacing seals generally around 150k - 200k on 1st gen Toyotas. That's why I said they generally start to fail around that time.
    Im sure it varies between drivers and trucks :notsure:.
