Stupid 4wd question?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VLTHNTR77, Aug 2, 2019.
  1. Aug 2, 2019 at 4:18 PM
    VLTHNTR77
    VLTHNTR77 [OP] Well-Known Member
    Andrew
    Everett, WA.
    2016 Inferno TRD off-road
    RCI skid and sliders, GoodYear Ultraterrains, HID's, SCS SR8s, lots of ME-SO goodies, Diamondback HD.
    I've had my 2016 TRDOR for 3 years now.
    My other truck is a 1977 International Scout SSII that I've had for 32 years.
    I know that there is a pretty substantial difference in the 4wd systems between the two.
    The Scout having manual locking hubs and a manually shifted t-case.
    My question is whether or not the front axle on my Tacoma is always free spinning as if it had
    hubs that were locked but the t-case isn't in 4wd?
    I do that with my Scout every now and then to keep the front diff lubed.
  2. Aug 2, 2019 at 4:20 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Per the manual you should drive 10 miles a month in 4wd to keep everything lubed up
  3. Aug 2, 2019 at 4:22 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Its not spinning when disengaged.
    You’ve got to post a pic of the Taco and Scout together!
    StayinStock likes this.
  4. Aug 2, 2019 at 4:25 PM
    VLTHNTR77
    Andrew
    Everett, WA.
    So, do the hubs lock in only when torque is applied?
    If so then it's similar to the old LOCK-O-MATIC hubs.
  5. Aug 2, 2019 at 4:29 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I assume your Scout is a solid front axle, your Tacoma has an IFS independent front axle system. One CV axle on either side of the front diff.
    With IFS the CV axles are constantly spinning on Tacomas even in 2wd because of the ADD system. With manual hubs, when they are unlocked the axles do not spin.
    Part of the reason some people do manual hub conversions on their later model Tacomas. It can be argued that CV axles constantly spinning adds wear and tear to them over time even though 4wd isn't engaged. But, CV axles on ADD Tacomas are beefier than the CV axles used on manual hub Tacomas (back when they used to make manual hubs on Tacomas anyway).
    That being said, just because the CVs are spinning does not mean you're properly working the 4wd system...to keep it lubricated and functioning reliably you should exercise it by putting into 4wd on the *appropriate surfaces every now and then
    * cue endless TW debate about 4wd and surfaces
  6. Aug 2, 2019 at 4:29 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    No. The hubs are “locked” all the time. Toyota uses an ADD system, like most others do these days.
    The best learning guide out there:
    https://m.youtube.com/watch?v=47m7QAPrpsI
  7. Aug 2, 2019 at 4:33 PM
    OnHartung'sRoad
  8. Aug 2, 2019 at 4:36 PM
    Stocklocker
    17TRDORDCSBAT
    No. The device that allows the front wheels to freewheel is the ADD device, which resides in the passenger side axle front tube. It is separate from the transfer case. That video is long and somewhat boring, but lays it all out. You will be an expert if you sit through it. Might save your ass on the trails.
  9. Aug 2, 2019 at 4:56 PM
    Stocklocker
    17TRDORDCSBAT
    tonered likes this.
  10. Aug 2, 2019 at 5:32 PM
    OnHartung'sRoad
    Hey, don’t accept an error without checking the reference I sent first! It may be in error, not you.
    I will have to watch the video, to be honest I’m really not that familiar with the newer Tacoma 4WD system. Back in the old days, we had to twist stuff like screwdrivers, keys and hubs to get things to work, not push a button! :p
    Stocklocker[QUOTED] likes this.
  11. Aug 2, 2019 at 5:39 PM
    Stocklocker
    17TRDORDCSBAT
    I really like that video, and the fella that does them. I think he’s a teacher of other mechanics. I believe he’s in a wheelchair. Anyways......we’ll worth the view. He goes into the ADD in depth in the second half of the vid.
    It is good to understand how the truck works, even if you are not working on these systems yourself. Can really help when you are trying to figure out what’s Fubar.
  12. Aug 2, 2019 at 5:54 PM
    OnHartung'sRoad
    You know what? The Center Axle Disconnect is the same thing as Toyota calling it the ADD or Automatic Disconnecting Differential.
    Good video, thanks!
  13. Aug 2, 2019 at 6:49 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Good video. Learned a few tings.
    OnHartung'sRoad likes this.
  14. Aug 2, 2019 at 6:52 PM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    I've been researching converting to manual hubs to eliminate the constant spinning. Do you know of any kits on he market?
  15. Aug 2, 2019 at 6:55 PM
    eon_blue
    Azusa, CA
    I don't know of one for 3rd gens...I know there's a kit for 2nd gens or at least there used to be, but I don't know if it would work or not.
    The CV axles spinning all the time isn't necessarily going to hurt them unless you have a lift to where the boot fins are rubbing, then they'll rub apart in short order.
  16. Aug 2, 2019 at 8:37 PM
    VLTHNTR77
    Andrew
    Everett, WA.
    Thanks for all of the great info everybody.
  17. Aug 2, 2019 at 8:39 PM
    VLTHNTR77
    Andrew
    Everett, WA.
    Here you go Bob.:)IMG_0093.jpg
  18. Aug 2, 2019 at 8:56 PM
    AZn8v
    AZn8v Well-Known Member
    2019 TRD OFF-ROAD
    Nice rig!
  19. Aug 2, 2019 at 9:12 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just a note that the 2Lo Mod (2LM) is shipping out:
    https://www.tacomaworld.com/threads...-2wd-low-range-for-the-3rd-gen-tacoma.614743/
    Installed it yesterday and is just freaking stellar. It will mostly do what putting it in 4Hi without locking the hubs does. You just want to be sure to cycle it into real 4Hi every once in a while to keep the ADD actuator happy.
    Also, there are manual hubs for the 2nd and 3rd Gens:
    https://www.tacomaworld.com/threads/free-wheel-hub-conversion-3rd-gen.513930/
  20. Aug 2, 2019 at 10:40 PM
    StayinStock
    StayinStock Dare to be the same
    Bob
    Missouri
    Yes I do
    Some
    Very nice! Thanks
