Stupid Cleaning Question
Discussion in 'Detailing' started by AzamWest, Oct 19, 2009.
  1. Oct 19, 2009 at 3:01 PM
    AzamWest
    AzamWest [OP] Member
    Fred
    08 Double Cab V6
    Yes this may sound stupid but I want to know if I am able to do it. I have a lot of dirt built up on under my hood on the engine block hood. I was wondering if I could just hose it all down. Or if there are any other techniques to clean it. I am kind of a clean freak at times with my truck.
    Any answers?
  2. Oct 19, 2009 at 3:03 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Toss a grocery bag over your Alternator, battery and fuse box and go nuts. Try not to spray the engine itself really hard with a powerwasher if that's what you're using.
  3. Oct 19, 2009 at 3:06 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    actually, you can just go to your local DIY car wash and spray down your engine. You dont really have to cover anything up, jus dont DIRECTLY spray at your alternator. Make sure your fuse box is tightly close. Your battery will be fine. I spray my compartment all the time, I just always have some electical cleaner and spray my alternator and battery terminals with it before I start my truck back up.
  4. Oct 20, 2009 at 3:21 AM
    AzamWest
    Fred
    08 Double Cab V6
    awsome thanks!
  5. Oct 20, 2009 at 11:53 PM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    just what i was about to ask :) haha
  6. Oct 21, 2009 at 12:12 AM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I think this is the best way to go about it and this is the way I clean the engine compartment. I'm sure it would be fine without doing this approach, but why risk anything.
  7. Oct 21, 2009 at 11:38 PM
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    honestly, leave ur truck on 5 minutes prior, hose it all down. u dont need bags just dont spray directly on the fuse box alternator or battery. spray diluted degreaser under the hood and over the engine, let it sit for a minute then rinse. shit put some dressing on the plastic too. ive done this before. make sure the engines on the whole time
  8. Oct 22, 2009 at 1:27 AM
    Blue Tango
    Blue Tango Well-Known Member
    Hampton VA
    06 PreRunner TRD Offroad Speedway Blue
    Westin Bull Bar
    I have most of the products from Adams Polishes at the moment and hit the underside of the hood with some All Purpose Cleaner, took a boars hair brush to the painted areas, then hosed it all down. Did that to the whole engine bay in fact. No issues. Some of their VRT on all the plastic and my engine bay looked like new. I wasn't using a power washer though, just a regular hose and nozzle so it wasn't getting blasted that hard. Now I didn't run the truck for a while before doing this, the engine wasn't cold but it also wasn't at it's running temp.
  9. Oct 22, 2009 at 3:06 PM
    07_Tundra
    07_Tundra Member
    Same here, Adams products are excellent. Great company to deal with...
  10. Feb 12, 2010 at 5:53 PM
    SMOKED DC TACO
    SMOKED DC TACO Active Member
    Brad
    North Carolina
    2006 taco tinted smoke lights lift
    smoke tail lights, jdm fog lights, hids, 3 in lift, 20% front tint 1.3 % rear, 33" bfg km2
    i work at a honda dealership and we use a all purpose degreaser and a pressure washer. Leave the truck running and spray everything and let it sit for about 30 seconds then pressure wash good. To make the plastics look new, spray some vinyl spray on the plastics and will look brand new
  11. Feb 13, 2010 at 10:17 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    I would not use a pressure washer on my own personal vehicle...
    Just a hose on the shower setting a soft brush and some mild soap if your just trying to remove light road dirt
    If you have grease and grime then it's time to break out the degreaser
    I also cover the alternator and fuse box
  12. Feb 15, 2010 at 9:48 AM
    SMOKED DC TACO
    Brad
    North Carolina
    i spary under the hood once every 2 weeks and never had a problem with water getting anywhere it dont belong as long as you leave it running.
  13. Feb 17, 2010 at 9:24 AM
    lizard1
    lizard1 Well-Known Member
    Tucson
    Desert Sand Mica/4x4 off road w/lock rear
    Leer cap, rear TSB, BFG All Terrains 10 ply 265/75/16, mud flap trim, black badges, AFE filter, 3" Toytec lift, 884 OME coils, add - leaf, Bilstein 5100 all around
    I soak all engine components in gasoline then drive like a bat out of hell!
  14. Feb 23, 2010 at 5:12 PM
    SURFTACO
    SURFTACO Well-Known Member
    New Jersey
    09 Tacoma
    3'' Pro Lift, 275 70 17 Tires Rear Suspension TSB Flat Black Stock Rims Seat Belt Chime off Fog Lights On anytime Jet pilot interior All weather floor Mats Tonneau Cover
    Simple Green. Used it this weekend and the engine compartment came out looking good. I let my engine run for a little before spraying. As far as anything electrical goes, i tried not to "Soak" that area. I guess you have to remember that under the hood gets wet when it raining....just be careful...
