Stupid newbie light question
Discussion in 'Lighting' started by Lineback, Feb 6, 2021.
  1. Feb 6, 2021 at 7:30 AM
    Lineback
    Lineback [OP] Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
    So, I want to mount 4 or 5 LED lights to the top of my Prinsu rack, instead of a light bar. Most likely the Baja Designs LP9's. Is it possible to use only one hot wire positive + wire for each light in series to one switch, or do I really have to run 5 separate + hot wires and ground to each individual light? Planning to use a SwitchPros unit most likely.
  2. Feb 6, 2021 at 8:50 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Each of those are rated for a combined 6.12A draw, so let’s just round that to 7A. If you use 5 of those, you’re at a 35A power draw. That is conveniently what a few of the SwitchPros circuits are rated for.
    A key thing to keep in mind is wire gauge. For a run up to the roof from the engine compartment, you’re looking at 8awg (OFC) power and ground.
    I might suggest something like this post, where he makes a junction box for power and ground distribution. Scroll to post #3497
    https://www.tacomaworld.com/threads...ping-conus-only.599113/page-175#post-24341814
    Toy_Runner and Lineback[OP] like this.
  3. Feb 6, 2021 at 5:19 PM
    FlyinFuzzy
    FlyinFuzzy Member
    Wisconsin
    2015 TRD OR DCSB
    Everyone is a newbie at one point! Electrical on your vehicle is no joke either! My suggestion, do a LOT of research and listen to what others have to say. I am in the process of designing and laying out my electrical upgrade and I will be making a fuse/relay panel with a high amperage main breaker to the fuse panel and using relays for all currents over a few amps to be safe and keep switches very low current. There is a great wealth of info so dig in and do it right the first time!
    https://www.bluesea.com/resources/1437
    https://www.tacomaworld.com/threads/show-off-your-aux-fuse-panels.308677/
    Enjoy!
  4. Feb 8, 2021 at 9:36 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    So $2500 worth of lights and your hoping to save the $15 relays by daisy chaining them? I would be putting a relay on each light and linking the triggers instead.
    Roof lights that big are going to be awkward- probably whistle like crazy sticking up off the Prinsu as well. Also as other poster have said running wire gauge big enough and long enough to get up there is going to be a pain. In the end it isn’t an ideal spot for big lights. 2 or 4 across the grill would be better, closer to the battery for wiring, and with much less glare off the hood.
    Tacospike and Lineback[OP] like this.
