Stupid question about wheelin with an automatic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hiker, Aug 12, 2011.
  1. Aug 14, 2011 at 2:14 PM
    #41
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I stand corrected. Just field tested and it does shift. What was throwing me off is that compared to the Chevy Colorado I drive for patrol, the shifting in 4LO in the Tacoma at lower RPM's is very subtle, almost imperceptible.
    Of course my truck is a Double Cab Long Bed Sport and I can't see over the hood scoop so my observations probably don't count.
  2. Aug 14, 2011 at 2:23 PM
    #42
    Maticuno
    2011 Suburban 2500
    It's on page 168 in my manual:
  3. Aug 14, 2011 at 2:30 PM
    #43
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Interesting , it is definitely not in my manual under the transmission or 4 wheel drive sections , nor does it seem to be a correct statement
  4. Aug 14, 2011 at 2:49 PM
    #44
    OZ-T
    Peter North
    British Columbia
    Come to think of it , my manual is also in metric and has a sprinkling of french .
    :) :canada:
  5. Aug 14, 2011 at 2:56 PM
    #45
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Yeah I am wondering if 4th + low still does tow mode. If I use 4 instead of D each of gears holdsz longer instead of tranny trying to shift immediately to highest gear for fuel mileage.
  6. Aug 14, 2011 at 3:08 PM
    #46
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  7. Aug 14, 2011 at 3:18 PM
    #47
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sir, If you continue to throw shit fits in threads, you will be forced to leave......Thanks :p
  8. Aug 14, 2011 at 3:21 PM
    #48
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This VVVVV
  9. Aug 14, 2011 at 4:31 PM
    #49
    OZ-T
    Peter North
    British Columbia
  10. Aug 14, 2011 at 4:40 PM
    #50
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    WTF happened here? :spy: To answer the op you have two options, leave it in D and let the trans do the work or shift it yourself. I have done it both ways when I used to off road and saw no real differences, only difference is how many up shifts it does to your input example you put it in 2 and it goes from 1st to 2nd, etc.
  11. Aug 14, 2011 at 6:45 PM
    #51
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    Thanks for taking the time to make that video. I always just assumed the owners manual was right and that while in 4lo the tranny didn't shift on it's own. Being that I only use 4lo for slow crawling it's never shifted out of the gear I had it in.
  12. Aug 15, 2011 at 10:25 AM
    #52
    OZ-T
    Peter North
    British Columbia
    I did the same experiment as Christian this morning with the same results .
    I , however , was on a gravel road , could not see over the hoodscoop and had no ATRAC to rely on .
    Needless to say , I got stuck .
  13. Aug 15, 2011 at 1:07 PM
    #53
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Usually leave mine in 2-3 depending on how fast I want to go, just like you'd do with a M. Drop it to 1st for the technical stuff
  14. Aug 15, 2011 at 11:42 PM
    #54
    Hiker
    Hiker [OP] Well-Known Member
    HotZona
    Thank you... after four pages of replies... I have a simple answer..
    OK... So what's ATRAC?
    Also...what different models of Tacomas are there. Are some better for offroad?
  15. Aug 16, 2011 at 12:56 AM
    #55
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    Ah whippersnapper you are you now my hero...haha
  16. Aug 16, 2011 at 3:19 AM
    #56
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    I only shift out of D in 4lo for 2 reasons. One to limit my speed on a downhill descent, and two for when I'm pulling something like my dad's tractor and don't want to go over 2 mph by it shifting to 2nd.
  17. Aug 16, 2011 at 8:27 AM
    #57
    Maticuno
    2011 Suburban 2500
    In my 2006 PreRunner I used the diff lock for it's best feature, to shut off the ABS. I've had it up to 65-70 blasting down the dirt California Aqueduct service roads. Never grenaded anything.
  18. Aug 16, 2011 at 9:19 AM
    #58
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The reason for suggesting a speed limit of 5 MPH isn't one of durability (as if the rear end would explode)... it is of control (safety).
    When the differential is locked, the tires are forced to rotate at the same speed... which is fine if going straight. However, when you turn all tires must rotate at different speeds... You loose some steering abilty... and the faster you go, the more sudden or dramatic that would be in avoiding hitting a tree, boulder or driving off a cliff.
    The A-TRAC system gives the Off Road Tacoma the traction of front and rear locking differentials, but does NOT affect steering.
    To get the traction of A-TRAC in a truck without it would mean to add front and rear locking differentials.
    The Off Road 4WD Tacoma (2009+) has both a locking rear differential and the A-TRAC device... so you can select one, both, or neither when you are four wheeling in low range. CHOICES!
  19. Aug 16, 2011 at 9:25 AM
    #59
    BlueT
    NorthEast
    You are 100% wrong :D
    the rest of your post is just as correct as the first part.
