stupid questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GreenMeanie, Jun 9, 2008.
  1. Jun 9, 2008 at 10:09 AM
    GreenMeanie
    GreenMeanie [OP] Member
    PHX
    05 with black tires
    will list later.. still testing
    Hey all, just signed up today here, so far its lookin pretty cool... so I have a couple questions....
    my drive belt, it started makin noise the other day, so I figured I'd tighten it up a bit... but where do I tighten it? I didn't notice any adjusters when i glanced under the hood.. any help would be appreciated...
    2nd question, does a 2005 have a MAP sensor? Manifold Air Pressure sensor?
    thanks in advance...
    KD:D
    and this thing is pingin too, even with 91oct... maybe I need new plugs er something. its got 62k miles... ??? bought it used at 30k.. probably still the originals... ??:eek::eek:
  2. Jun 9, 2008 at 10:16 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    1. Serpentine belts are auto-tensioned. If it's slipping, replace it. New ones are cheap and it'll take 5 minutes.
    2. Most likely. Get yourself a ScanGauge and you'll be able to see all kinds of neat stuff coming from the truck's computer.
    3. Pinging or ticking? The ticking (you'll even hear it at idle) is expected on the 05+ v6 engines. Don't sweat it.
    Welcome to the site!
  3. Jun 9, 2008 at 10:24 AM
    GreenMeanie
    PHX
    05 with black tires
    thanks for info!! i'll get a new belt asap...
    its definately pinging.. :(
  4. Jun 9, 2008 at 10:28 AM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    Welcome Meanie....My thoughts as well,replace the belt and you've got the "Tacoma tick"....It's what they do.:)
  5. Jun 9, 2008 at 10:54 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    There is a MAP sensor in the intake (Be CAREFUL if you get a K&N filter) but as far as I know the information from it is invisible to the scangauge.
  6. Jun 9, 2008 at 11:56 AM
    GreenMeanie
    PHX
    05 with black tires
    I was looking in the Repair Manual, and can't find anything on the MAP sensor, I am trying to find it so I can tap into the wiring... any ideas?
  7. Jun 9, 2008 at 12:18 PM
    mjp2
    NJ
    Since this is a "stupid questions" thread I figure I'll blend right in. :p
    I thought what's on the intake is the MAF (Mass Air Flow) sensor. That's not the same as the MAP (Manifold Absolute Pressure) sensor, right?
  8. Jun 9, 2008 at 12:54 PM
    Roland
    Rhode Island
    Doh!
    I stand corrected. !@#$ acronyms.
    Sorry about that :eek:
  9. Jun 9, 2008 at 12:59 PM
    GreenMeanie
    PHX
    05 with black tires
    :D ok.. got it.. I found the MAF.. and have figured out how to tap it.. I was hoping there wasn't another MAP sensor too... Thanks!!
    later
    KD
