Stuts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Overthehill2, Oct 26, 2013.
  1. Oct 26, 2013 at 4:53 PM
    Overthehill2
    Overthehill2 [OP] Member
    Joe
    California
    2002 Tacoma 4x4 TRD
    Just finished installing Bilstein Struts (24-022842) on front of my 2002 trd.
    After finishing and letting the truck to the ground I notice the top strut screws are tightened all the way down to the end of the threads, but there is about a 1/2" gap left to the top of the bushing that was not there with the old set. I didn't like it so I put in some washers to fill up the space. Has any one had this problem?
    Thanks
  2. Oct 27, 2013 at 6:51 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Did you have a top plate spacer before? You could redo the coil spring and replace the bolts with shorter ones but I would probably do what you did and add a nice stack of washers and call it a day. It won't hurt anything.
    Edit: are you asking about the center nut on the shock or the 3 bolts that hold the whole assembly in place? My advice was for the 3 bolts. If it's the center stud, you have another problem.
  3. Oct 27, 2013 at 7:00 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Any pics of the issue?
  4. Oct 27, 2013 at 9:44 AM
    Overthehill2
    Joe
    California
    2002 Tacoma 4x4 TRD
    Thanks for your reply. I found the problem when I looked at the old struts. I had not removed the old top rubber/washer assembly and put it on the new ones. At this point I do not want to pull it all out and put it in so there will not be a cushion between the top of the shock and the mounting plate. Maybe if I have energy I will pull it apart and put it in.
  5. Oct 27, 2013 at 2:12 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    You should put the bushing in.. Best to have everything properly assembled
