Stuttering, and sounds from the engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by HamerMan, Oct 17, 2013.
  1. Oct 17, 2013 at 10:57 AM
    HamerMan
    HamerMan [OP] No brakes on this rape train
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
    Hi guys, I'm getting some stuttering when I'm hard of the throttle. I seafoamed the engine a few days ago, and nothing has been the same. It sounds like theres something holding it back at low RPMs and at higher RPMs (above 3.5k) it makes a popping noise. I'm at a complete loss at what it could be:(
  2. Oct 17, 2013 at 3:14 PM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    What process of seafoaming did you use? Where and how did you do it? Sounds like a misfire... No codes?
  3. Oct 17, 2013 at 3:57 PM
    HamerMan
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
    No codes. I did vacuum line and gas tank. Would aftermarket exhaust have anything to do with it?
  4. Oct 18, 2013 at 6:51 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    Spark plugs and wires. Mine did the same thing. Finally, a few weeks later it threw a code.
  5. Oct 18, 2013 at 6:55 PM
    HamerMan
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
    Would anything about the way I drive do that to the plugs and wires?
  6. Oct 18, 2013 at 6:56 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Not really. How many miles do you have on this set of plugs and wires?
  7. Oct 18, 2013 at 6:58 PM
    HamerMan
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
    No idea. I've only had it for about 3k miles
  8. Oct 18, 2013 at 7:10 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    How many miles on the truck?
  9. Oct 18, 2013 at 7:16 PM
    HamerMan
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
  10. Oct 18, 2013 at 7:22 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Put some Genuine Toyota plugs and wires on it and never trust "pre-gapped" plugs, even from Toyota.
  11. Oct 18, 2013 at 9:04 PM
    HamerMan
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
    Alright. Thanks man:thumbsup:
  12. Oct 18, 2013 at 11:00 PM
    994x4wd
    994x4wd Active Member
    Warner robins ga
    99 sr5 4x4 bone stock (for now)
    Hey Hamer man I just bought my truck last Saturday, love it to death! First thing I did was wash it and run Seafoam through vacuum line and gas tank.... About 20 miles later the truck starts shaking just like your truck is doing, swapped the plug, wire, coil pack, everything I could think of and it was driving me nuts, then I got to thinking, what if it was the Seafoam?!?!?!?! so after a little swapping parts around between my tacoma and my 4runner I found out that Seafoam had knocked some crud loose and clogged my fuel injector!! So check out the easy stuff first but keep in mind that you might have the same situation I did, hope this helps
  13. Oct 18, 2013 at 11:04 PM
    HamerMan
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
    :wave:
    It was doing it a little bit before the seafoam, just more pronounced after the seafoam
    Welcome to TW:wave:
  14. Oct 19, 2013 at 9:00 AM
    994x4wd
    Warner robins ga
    Thanks buddy hope you get it figured out!
  15. Oct 19, 2013 at 9:36 AM
    HamerMan
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
    Thanks man. My cousins coming out next week from California. He's managed to turn a ford into a deacent off road vehicle, so he can probably help me get this figure out
