Sub Box '04 Dcab
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ska Himself, Nov 4, 2010.
  1. Nov 4, 2010 at 1:40 PM
    Ska Himself
    Ska Himself [OP] Well-Known Member
    I know there are issues with mounting any sort of decent sub box in an '04 Dcab unless you're willing to toss an unweildy box in the back or settle for some 10" shallow mounts (or some 8"s) behind the seats.
    But what about the floor? Why couldn't you build something that takes advantage of floor space?
    I attached a shitty diagram to give people an idea of what I am thinking. Ideally it would stretch from door to door across the back (50"), be wide enough that the front seats can slide back all the way (9"), and tall enough that it clears the tranny hump in the middle while taking advantage of that space for a couple extra inches (8") of air flow.
    If my calculations are right, you should be looking at ~ .6776 cubic feet on each side (if you divide it into 2 boxes). I know volume can be improved by taking advantage of actual angles in the truck floor + tranny hump + rear seat vs the 90 degree angles I drew.
    Thoughts? Improvements?
  2. Nov 4, 2010 at 2:23 PM
    SlimDigg
    SlimDigg Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
    Why did you buy a double cab? :confused:
  3. Nov 4, 2010 at 2:34 PM
    Ska Himself
    It was an '04 w/ 37K for <$20K (bought it in Jan).
    Why not buy it?
    If you're alluding to being able to haul people around, well, I'm trying to work that out with this design. But frankly, this truck isn't the family chauffer and I rarely have more than 1 passenger.
  4. Nov 5, 2010 at 2:31 PM
    RPain
    RPain I drink, and I break things
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    personally i like the box i have behind my back seats. fits 2 8" subs and it sounds beast. plus i can still utilize my back seats for hauling people around.
  5. Nov 6, 2010 at 12:09 PM
    fastguy95
    fastguy95 A man knows nothing
    SF Bay Area
    02 DC 4wd
    All Pro front/rear bumpers, OME 883's with Bilstein 5100 all around, Deaver J59 springs, TRD E locker, E locker Guard, Red Line hood struts, Weathertech floor mats, SS brake lines, EBC Rotors and green pads, Debadged, Line X, BAMF brake relocator bracket, Beefed Taco cb drop, Magnaflow muffler, Scuba Mod, live power outlet mod, disable door buzzer mod, tinted windows, light blinker conversion, Alpine HU, Infinity Kappa 600w amp, JL Audio 1000w amp for sub, JL Audio W3V4 12" sub, JL Audio 6x9's, Retrofit projectors bixenon 55w, Dynamat on all doors, and light bar.
    Hey Ska.
    I was pondering the same thought: if they can build a sub enclosure box for behind the dcab seats, why can't they build it for under the dcab seats?
    I did some browsing, and found this thread:
    http://www.diymobileaudio.com/forum...ed/29557-jl-audio-thin-line-subwoofers-3.html
    A guy there has a sub enclosure box under his double cab seat in his tundra! So I do believe it IS possible, just not sure how to go about it as I'm not that savy when it comes to electronics. :(
    I am interested in this thread as I'd like to put some subs in my dcab as well. I know Pioneer makes the shallow 10's and 12's, Alpine has the typeR in a shallow 12, and JL Audio makes a shallow 13.5!!! :eek:
    subscribed to this thread in case there's more info posted!
  6. Nov 6, 2010 at 12:16 PM
    04coma
    04coma Well-Known Member
    Justin
    Temple Texas
    04 trd offroad sr5 prerunner debadged
    air aid intake and throttle body spacer billet grill clear corner lights and 3rdbrake decal "coma" :)
    where did you get this box and what do you have in it?
  7. Nov 6, 2010 at 2:08 PM
    RPain
    Chandler, Arizona
    i bought it from a member on here but it looks just like this one.
    https://www.soundoffaudio.com/item.cfm/id/2118
    I'm running 2 8" pioneer subs powered by an 800W pioneer amp.
  8. Nov 7, 2010 at 8:50 AM
    Ska Himself
    Believe me, I've looked at your set-up numerous times and I like what you've done. I'm just trying to decide whether or not I am going to go with the 8"s (like you did), a 10", or do a custom enclosure and try and fit a 12" or 2.
    I re-measured everything and I could fit 2 12"s on the floor in a custom box that spanned the back, but I would be giving up all of my floor space.
  9. Nov 7, 2010 at 2:25 PM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
  10. Nov 7, 2010 at 4:14 PM
    747 function > form
    1st Gen.
    ^ x2. Conti's .pdf plans attached. I'd prefer a 10 or 12, but I haven't seen it done this clean.
  11. Nov 18, 2010 at 6:11 PM
    747 function > form
    1st Gen.
    Here's a simple DC install...
  12. Nov 18, 2010 at 6:21 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    it all depends on the amount of space your subs require. if you dont have the correct volume of air in the box they wont work as efficiently as they should and you wont get the bass you are looking for.
    i bought a sub enclosure from bright star car audio which holds 2-rockford fosgate p3 shallow mount 10s driven by a power series 500.1 amp(776 true watts) it has .77 cubic ft. of volume and is rediculously loud. and it all fits neatly behind the rear seat.
