sub box question. hope someone can help
Discussion in 'Audio & Video' started by 2011BlackTaco, Feb 13, 2012.
  1. Feb 19, 2012 at 8:01 PM
    2011BlackTaco
    2011BlackTaco [OP] Well-Known Member
    Josh
    Tennessee
    11 Prerunner
    6 inch Pro Comp lift kit, 18" XD Monster rims, 285/65/18 Nitto Trail Grapplers, Smittybilt black step bars
    i have pretty much decided to follow this advise cause i cant get good power out of the smaller area so i am looking into getting two 10's instead of the one 13. Does anyone have any negative sides to these subs i have heard them and they sound really good !!!!! Give me input on them if you have any
    http://www.memphiscaraudio.com/products/subwoofers/memphis-reference-subwoofers/
  2. Feb 20, 2012 at 3:04 PM
    NOCENTS
    NOCENTS Well-Known Member
    Arm pit of Cali
    08 TRD DC needin some lovin
    loooooong list of mods coming as soon as I finish the audio/video system
    You dont have to use the flat subs. PR or M1 will fit and are cheaper.
  3. Feb 20, 2012 at 3:13 PM
    Aw9d
    Aw9d That one guy
    I can't see but where you able to keep the back plastics on the rear passenger seat with this setup?
  4. Feb 20, 2012 at 3:22 PM
    ratrod
    ratrod Well-Known Member
    Los Angeles
    2006 Toyota Tacoma Dbl Cab TRD SR5 4x4
    Bilstein 5100s @ 1.75 with 1.5 AAL, Satoshi Grill Mod with 2 Hella 500s behind the grill, LED dome and map lights, custom made (by me) 10" subwoofer box behind the dbl cab seat, DVD/iPod/Bluetooth/GPS/TV/USB/Stereo, Yakima rack, Shell, tinted front windows to match the factory backs. Backup cam in the tailgate handle mod.
    When you decide to upgrade let me know I'll take that box! Nice work!
  5. Feb 20, 2012 at 3:24 PM
    monte1985
    monte1985 Well-Known Member
    Stan
    Lancaster NY
    09 Tacoma Dbl Cab 4.0 S/C
    Supercharger, Magnaflow Exhaust. Audio System . Gauges TRD CAI
  6. Feb 20, 2012 at 5:03 PM
    NOCENTS
    Arm pit of Cali
    There is plenty of room when the seats are up but the back does touch when folding down........ as soon as Im doing showing it off I will put the back on.......
  7. Feb 20, 2012 at 5:05 PM
    NOCENTS
    Arm pit of Cali
    Thanks!!!! Funny you should say that...... I have already thought about my next set up.....
    and jut finished my ipod dock also
  8. Feb 20, 2012 at 6:44 PM
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
    im looking at the shallows because of the required air space, they only need .35 per sub
  9. Feb 20, 2012 at 9:21 PM
    NOCENTS
    Arm pit of Cali
    OP are you going to keep the left side storage bin? What amp and where are you going to put it?
  10. Feb 20, 2012 at 10:00 PM
    NOCENTS
    Arm pit of Cali
  11. Feb 21, 2012 at 5:08 AM
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
    The amp I am using is the jl 600/1 xd which is a small enough amp to go under the driver seat
  12. Feb 21, 2012 at 11:56 AM
    NOCENTS
    Arm pit of Cali
    OP if you dont have stuff to put in the bins you will have more then enough air space for 2 10" subs I have almost 6 of depth and with a full width box it will be much easier to blend it in. I was also worried that anything I put in the bins would rattle anyway.
    Just my .02
    And im guessing you found out that the difference between the subs you listed was the MR is the newer version?
  13. Feb 21, 2012 at 6:15 PM
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
    well im taking out the passenger side bin and installing a custom box from Mr. Marv when i have the money to order everything at once.
    Yeh i figured out the difference, the MR has been out for a little while i think. The SC is discontinued
  14. Mar 20, 2012 at 3:17 PM
    Aggiesdm
    Aggiesdm Well-Known Member
    San Antonio
    17 TRD OR 4X4
    SnugTop topper, WeatherTec mats, thats all for now
    I really like the filler cap, can you give me a rough idea of how you built it? I'm putting a box/amp rack on the passenger side and leaving the driver side bin in place but wanted a more finished look like yours.
  15. Mar 21, 2012 at 3:36 PM
    #35
    NOCENTS
    Arm pit of Cali
    I made a template out of cardboard so I could see where the seat latches are and length, used some 1/8 wood I had already laying around. Cut out that shape, used some 1/4 round molding for the top. I did cut a groove into the face of the mouling to get the 1/8 panel to sit flush afer glued and stapled it together. Then with some 1 X 1/2 scraps I used that as the bottom leaving just a little room for carpet. Drilled a hole on each side in the molding to fit the studs that come out the back of the back glass.
    Carperted and atached. If I did it again I would scew in the clips from the front to the back to atach where the bins clip in to the back wall. But even with the bass pounding it doesnt rattle so will wait till I build a ported box and move my amps to under the back seat before I redo it.
    If you want more info PM me.
    Hey OP how is your set up coming???? Any pics????
  16. Mar 22, 2012 at 7:43 PM
    #36
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
    well right when i was ready to pull the trigger on the order some issues came up that needed my money instead so nothing yet but tax return is in and im about to order everything ill post pics when i get it all installed.
