Subway4X3 Shameless Copycat Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Subway4X4, Nov 7, 2016.
  1. Oct 4, 2017 at 3:47 PM
    #461
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    have you reached out to wyatt at RST??
    I have not, but I plan on it before buying everything myself.
    IIRC the fj case jimmy installed had the twin stick modification performed by RST right??
    idk how easy the retro fit stick mod is to complete, might be worth maybe shipping any parts you buy over into the RST work shop for the twin stick?
    Blackout14 likes this.
  2. Oct 5, 2017 at 6:51 AM
    #462
    cynicalrider
    cynicalrider #NFG
    Jersey
    This. Then you can save your ADD tube and all the electronics if you ever want to put it back in.
    Also there are two conversations going on here, seems some people have a difficulty separating the thought that an fj case is a completely different mod than doing the fj tube conversion.
  3. Oct 5, 2017 at 7:04 AM
    #463
    cynicalrider
    cynicalrider #NFG
    Jersey
    There is a shift fork the actuator moves. The shift fork moves a collar that locks the two shafts together.
    This is the collar the shift fork moves:
  4. Oct 5, 2017 at 7:11 AM
    #464
    Subway4X4
    Subway4X4 [OP] Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Yup. I was totally confused.
    When @jowybyo mentioned FJ ____ to me at AAOA, I thought he meant FJ Tube.
    And as I am reading and understanding more about the FJ and Stock Tacoma tubes from all you guys, I think I want to go with stock tube, fully engage the front with no welding and just put a dummy plug into the the harness.
  5. Oct 5, 2017 at 7:17 AM
    #465
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What I'm wondering is if the easy way (shift into 4wd then unplug) works the same, why not just do that? Or does it light up your dash like a christmas tree.
    ChadsPride and Blackout14 like this.
  6. Oct 5, 2017 at 7:24 AM
    #466
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Does anyone know how the 4x4 ECU will react to this?
  7. Oct 5, 2017 at 7:26 AM
    #467
    Subway4X4
    Lloyd
    NY/NJ
    Good question.
  8. Oct 5, 2017 at 7:27 AM
    #468
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Easily answered. Try it.
  9. Oct 5, 2017 at 7:29 AM
    #469
    Subway4X4
    Lloyd
    NY/NJ
    Engage 4WD and unplug the actuator?
    Then drive it?
    ChadsPride likes this.
  10. Oct 5, 2017 at 7:30 AM
    #470
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    The 4x4 dash light is triggered by the sensor in the t-case, not the ADD in the front diff. Therefore if one were to swap out the stock actuator for the full-time engaged FJ one there would be no lights on in the instrument cluster. By swapping with the "FJ tube" you eliminate the need for a separate switch to engage the front. Ant has done this, however I have not and still have the stock actuator.
  11. Oct 5, 2017 at 7:31 AM
    #471
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Then shift back to 2wd, if I'm following this plan correctly. That way it stays engaged.
  12. Oct 5, 2017 at 7:38 AM
    #472
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    There you go.
    I have the tube, but also the FJ case. So, I removed the 4x4 ECU. Wasn't sure how the electronics worked exactly.
  13. Oct 5, 2017 at 7:42 AM
    #473
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    You need both to really get the advantage of the that swap. Just eliminating the actuator is a lot of work for taking out one electric motor.
  14. Oct 5, 2017 at 7:42 AM
    #474
    uurx
    '12 t|x pro
    you also have a twin sticked fj case, making it a little different as well as far as deciding to go full fj tube..
  15. Oct 5, 2017 at 7:55 AM
    #475
    Subway4X4
    Lloyd
    NY/NJ
    OK. This conversation is helping me a bunch.
    I am going with the OEM Tacoma Tube.
  16. Oct 5, 2017 at 7:57 AM
    #476
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Glad to assist. :hattip:
    Blackout14 and ChadsPride like this.
  17. Oct 5, 2017 at 7:58 AM
    #477
    Subway4X4
    Lloyd
    NY/NJ
    Now I just gotta find and buy the tube. I have a quote request out to Camelback.
  18. Oct 5, 2017 at 8:17 AM
    #478
    uurx
    '12 t|x pro
    so are you gonna twin stick the fj case or just one stick??
  19. Oct 5, 2017 at 8:31 AM
    #479
    Subway4X4
    Lloyd
    NY/NJ
    That's a future thing. Right now I just need a viable tube.
    Nimble9 and Blackout14 like this.
  20. Oct 5, 2017 at 8:38 AM
    #480
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    hahaha that made me laugh
    Subway4X4[QUOTED][OP] likes this.
