Subway4X3 Shameless Copycat Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Subway4X4, Nov 7, 2016.
  1. Oct 7, 2017 at 11:27 AM
    #581
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Okay so the locker replaces your carrier and spider gears. The stub shaft goes from passenger side spider gear to your add housing. Add collar connects stub shaft to the axleshaft axle shaft connects to passenger side cv shaft. So if your 100% positive the stub shaft is in there then your locker has to be wonky
    Do you remember dealing with something like this???
    Blackout14 likes this.
  2. Oct 7, 2017 at 11:28 AM
    #582
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    I would think at this point though it doesn't matter because even moving the collar by hand he's got nothing
  3. Oct 7, 2017 at 11:30 AM
    #583
    Subway4X4
    Subway4X4 [OP] Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    @TNT4X4 @V5ioV do you recall this part of the process? I wasn't paying attention because I was crying over the loss of my anti-sway bar
    Wheelspinner[QUOTED] likes this.
  4. Oct 7, 2017 at 11:30 AM
    #584
    Subway4X4
    Lloyd
    NY/NJ
    This^^^
  5. Oct 7, 2017 at 11:31 AM
    #585
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Ah gotcha. So with the collar engaged the wheels still don't spin if he rotates the driveshaft?
  6. Oct 7, 2017 at 11:32 AM
    #586
    Subway4X4
    Lloyd
    NY/NJ
    Isn't the collar supposed to be closer to the diff side, when 4WD is engaged? That's what it shows on the pic.
  7. Oct 7, 2017 at 11:32 AM
    #587
    Subway4X4
    Lloyd
    NY/NJ
    correct
  8. Oct 7, 2017 at 11:33 AM
    #588
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Nice post
  9. Oct 7, 2017 at 11:33 AM
    #589
    jowybyo
    Joe
    Baltimore, MD
    Yes. The pic of the collar looked correct but the actuator looked backward.
  10. Oct 7, 2017 at 11:33 AM
    #590
    Subway4X4
    Lloyd
    NY/NJ
    I did check the time when I put together the gears. I believe it's correct because (1) I was very careful and (2) it was idiot proof and would only go in one way.
  11. Oct 7, 2017 at 11:36 AM
    #591
    jowybyo
    Joe
    Baltimore, MD
    Nah. It's definitely not idiot proof. I've put it back together with the gears off by one tooth and it definitely seems like it's works right but it's not. I spent a whole weekend fucking with that thing trying to get the correct timing of the gears.
  12. Oct 7, 2017 at 11:38 AM
    #592
    jowybyo
    Joe
    Baltimore, MD
    If you took the black plastic cover off the actuator and pulled the plastic gears out, it's extremely annoying trying to figure out the correct mesh timing to get it to work correctly.
    uurx likes this.
  13. Oct 7, 2017 at 11:41 AM
    #593
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    i made this mistake.... lol
  14. Oct 7, 2017 at 11:46 AM
    #594
    Subway4X4
    Lloyd
    NY/NJ
    Take a look again @jowybyo before I change anything:
    For reference/orientation, we are looking underneath the truck from the front towards the rear. PS is left side. DS is right side. Actuator wire harness/plug is on the left side and actuator is hanging by the wires. Front diff is on the right side of this pic.
    2H:
    Actuator fork is on top in this pic. When actuator will be installed, the fork will be on the left side when the collar will be pushed all the way to the left (which is on the PS axle side.)
    4H:
    Actuator fork is on the bottom on this pic. If this was installed matched with the collar, then it will be on the right, the DS (towards the diff)
  15. Oct 7, 2017 at 11:53 AM
    #595
    Subway4X4
    Lloyd
    NY/NJ
    OK. I'll take a closer look at it again. You may be right.
    How would I know that it's off by one or two teeth?
  16. Oct 7, 2017 at 11:59 AM
    #596
    jowybyo
    Joe
    Baltimore, MD
    You have to check the continuity at the correct pins to make sure it going where it's supposed to. See my post from yesterday.
  17. Oct 7, 2017 at 12:00 PM
    #597
    Subway4X4
    Lloyd
    NY/NJ
    I confirmed that the stub shaft is 100% installed.
  18. Oct 7, 2017 at 12:01 PM
    #598
    Subway4X4
    Lloyd
    NY/NJ
    OK. I'll do that. Thanks.
  19. Oct 7, 2017 at 12:05 PM
    #599
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    He should be able to slide the collar to where the PS locks the stub and the intermediate, but he hasn't been able to see this, unless I missed it somewhere along the way?
  20. Oct 7, 2017 at 12:10 PM
    #600
    Subway4X4
    Lloyd
    NY/NJ
    The collar manually slides fully to either side: As I understand it, NOT engaged 2H (left side) and engaged (right side).
    The Stub and intermediate does NOT lock when the collar is manually moved to the 4WD side (right side)
