Subway4X3 Shameless Copycat Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Subway4X4, Nov 7, 2016.
  1. Nov 16, 2017 at 6:41 PM
    #881
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    No way I'm trying to do this with OBA when I have a real compressor.
  2. Nov 16, 2017 at 6:50 PM
    #882
    Subway4X4
    Subway4X4 [OP] Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Yeah. You have a giant compressor tank.
    I think my ARB OBA plus tank is better than my old Porter Cable compressor. Lol
  3. Nov 16, 2017 at 6:56 PM
    #883
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    I've done it. It works and definitly helps to have some knowledge of stick welding. Unlike a welder there is no way to control the amperage so you need to control the weld by manipulating the rod itself. It does work though
    :thumbsup:
  4. Nov 16, 2017 at 7:00 PM
    #884
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's a good point I didn't think about. I have an extremely basic level of welding knowledge and skill, but I think if the need arose I'd be able to booger weld something together as a last resort. Thanks!
    Wheelspinner[QUOTED] likes this.
  5. Nov 16, 2017 at 7:02 PM
    #885
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Oh, I thought you had s big compressor
  6. Nov 16, 2017 at 7:03 PM
    #886
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    You can do it here one weekend when I'm not using the garage if you'd like.
  7. Nov 16, 2017 at 7:41 PM
    #887
    Subway4X4
    Lloyd
    NY/NJ
    :thumbsup:
  8. Nov 23, 2017 at 4:59 PM
    #888
    Subway4X4
    Lloyd
    NY/NJ
    Today, I was messing with my front end/shocks. Now the top hats are brand new and all of the shock/top hat rubber is nice and fresh.
    Probably have pulled the shocks about 5 times now using the no coil compressor method.
    We now I have a new problem and I could use some help figuring out the solution.
    Four lights on the dash are now it up: ABS, VSC TRAC, Slip Indicator and VSC Off.
    What did I screw up?
    Edit: ABS Sensor looks plugged in and OK.
    @stairgod @Sub-Zero @Fifthwind @Wheelspinner @loosnut and others?
  9. Nov 23, 2017 at 5:09 PM
    #889
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I believe all of those systems are tied into that sensor. I'm confused, what were you doing to the truck? New top hats?
  10. Nov 23, 2017 at 5:19 PM
    #890
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Do they go away if you unplug the battery? That'd be my very first step is to do that to see if they go away and magically fix themselves. Simple, fast and free.
    Fifthwind likes this.
  11. Nov 23, 2017 at 6:29 PM
    #891
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    its possible you damaged one of the abs wires. They are very delicate and I've damaged one while working on the front end by stretching it. There is a writeup on here somewhere about how to test with a jumper wire in the obd2 port to narrow what corner of the truck is causing the issue. Please hold
  12. Nov 23, 2017 at 6:36 PM
    #892
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Well Floyd, you win the prize for lighting up the dash. If I had this, I would make sure that I didn't pinch the cable to the sensor, or tweak the sensor. Since you probably have a spare, connect to the spare to the cable and see if the Christmas lights continue. Disconnect the battery repeatedly, and go through a full ignition and start cycle. Do you get and OBD code?
  13. Nov 23, 2017 at 6:39 PM
    #893
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
  14. Nov 24, 2017 at 5:33 AM
    #894
    Subway4X4
    Lloyd
    NY/NJ
    Yeah.
    Usually my Christmas lights don't go up until mid December.
    I started early this year:
    Blackout14 likes this.
  15. Nov 24, 2017 at 5:44 AM
    #895
    Subway4X4
    Lloyd
    NY/NJ
    Thanks guys!
    Today is gonna suck in the cold. I want to get this fixed today. I wanna do some local light wheeling tomorrow.
    Here is my morning plan of attack:
    Step 1 EDIT: did not fix problem.
    Step 2 EDIT: I checked along the entire length of ABS cable both sides. No apparent pinching of cable. Also pulled and reseated both ABS sensors.
    Step 3a - Don't have a spare . Edit: Will order ASAP
    Step 3b - No current OBD code
    Step 4
    Steve- This is the most likely scenario. What if I determine it to be a ABS sensor or Speed sensor circuit wire to one of the front corners? How hard is it to change the sensor wire? Edit: Doesn't look to be that hard to change the ABS wire.
    Edit: I'm gonna do below procedure now to determine if Front Driver or Passenger side.
    @Lux - this might mess up my plans tomorrow
  16. Nov 24, 2017 at 6:45 AM
    #896
    Subway4X4
    Lloyd
    NY/NJ
    Yeah New Top Hats, coil spring rubber cushions and shock mount rubber bushings/cushions.
    13 year old top hat holes were excessively enlarged. I could visually observe that the shock rods weren't centered in the top hats.
    And it's always good to have fresh rubbers.
  17. Nov 24, 2017 at 7:20 AM
    #897
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm a huge fan of the no compresor method. I've done it a handful of times as well.
  18. Nov 24, 2017 at 9:10 AM
    #898
    Subway4X4
    Lloyd
    NY/NJ
    Hey Steve and others,
    Help me decipher the blinking pattern.
    ABS Dash Light blinking pattern
    I'm seeing:
    one, two, three pause one.
    But the next series I see:
    one, two, three pause one, two
    And then the next series I see:
    one, two, three pause one, two, three, four
    Last set:
  19. Nov 24, 2017 at 9:27 AM
    #899
    Subway4X4
    Lloyd
    NY/NJ
    I have 700# springs. Works no problem.
    But I have two batteries, 1/4" reinforced skids, BFF full hoop bumpers and a winch on board.
  20. Nov 24, 2017 at 12:35 PM
    #900
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Lloyd looks like your getting codes for both fronts and the driver rear circuit. That doesn't add up though because you haven't messed with the driver rear. Unless there is an insane coincidence, the only other thing I can think of that effects all three of those at the same time is your "brake actuator (skid control ecu)" As per this page in the fsm. Have you messed around under the dash and maybe bumped the plug for the plug for the abs ecu?
