Subway4X3 Shameless Copycat Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Subway4X4, Nov 7, 2016.
  1. Dec 5, 2016 at 12:04 PM
    #81
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I don't know I live 3000 miles from there
    Subway4X4[OP] and Crom like this.
  2. Dec 5, 2016 at 12:06 PM
    #82
    Subway4X4
    Subway4X4 [OP] Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Canadian Tire maybe?
  3. Dec 5, 2016 at 12:06 PM
    #83
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    :rofl:
    fatfurious2 and Nimble9 like this.
  4. Dec 5, 2016 at 12:11 PM
    #84
    Subway4X4
    Lloyd
    NY/NJ
    Damn. I thought Canada was just a little tiny country. With 3 gas stations and a movie theatre. LOL.
    Is there a national franchise that carries these?
    fatfurious2 likes this.
  5. Dec 5, 2016 at 12:49 PM
    #85
    OZ-T
    Peter North
    British Columbia
    Princess Auto has them
    Subway4X4[QUOTED][OP] likes this.
  6. Dec 7, 2016 at 12:24 PM
    #86
    Subway4X4
    Lloyd
    NY/NJ
    I'm getting ready to prep and paint my bumpers. I'm not going the powder coat route because I've gotten two estimates and they're in the 450-600 dollar range. Yes, I live in NY. Sigh.
    I'm going to rattle can my bumpers. First with self-etching primer, then with rustoleum satin black.
    The prep work will involve sanding to really roughen up the metal surface for good adherence.
    What prep work would you recommend y'all? What grit sandpaper? I have numerous mechanical sanding tools available. 6" round random orbit, 1/4" sheet random orbit, 4.5" angle grinder, 6" angle grinder, Oscillating tool with sanding attachments.
    What cleanup and prep chemical? I've heard anywhere from M.E.K., acetone, isopropanol, mineral spirits.
  7. Dec 7, 2016 at 12:27 PM
    #87
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    when I painted my sliders, I went over them with a scotch brite, acetone, self etching primer, and then paint.
    Has held up to me stepping on the same spot every day plus dailying it.
    Subway4X4[OP] likes this.
  8. Dec 7, 2016 at 12:28 PM
    #88
    Subway4X4
    Lloyd
    NY/NJ
    Thanks OZ. I might go this route with the MFC.
    They don't stock the black color MWC, so I'm still looking.
    I'm gonna try to rig up a simple pressurized water system for a primitive shower setup. Heat absorbent color Black is key to getting the water a few degrees warmer than ambient.
  9. Dec 7, 2016 at 12:29 PM
    #89
    HeavyThumbs
    HeavyThumbs Well-Known Member
    Phoenix, AZ
    2015 MGM TRD 4x4 OR AC
    Snugtop shell, group buy addiction
    I've used acetone for prep on a LOT of metal surfaces that I've rattle canned. It works great. I've also had good results using mineral spirits, but not as good as acetone.
    Crom and fatfurious2 like this.
  10. Dec 7, 2016 at 12:30 PM
    #90
    OZ-T
    Peter North
    British Columbia
    You should be able to buy the MWC in the US , its only the MFC you can't get new
  11. Dec 7, 2016 at 12:30 PM
    #91
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Id just do acetone and then primer.
  12. Dec 7, 2016 at 12:30 PM
    #92
    Subway4X4
    Lloyd
    NY/NJ
    I'm a little concerned with acetone. Nick @Crom used it and had minor issues with his bumper paint job.
  13. Dec 7, 2016 at 12:33 PM
    #93
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Krud Kutter metal prep. No sanding required.
    Wash down the parts with the metal prep (wear gloves). I "sanded" the entire surface with a green Scotchbrite pad and KK, then rinsed. Make sure you rinse off all the KK.
    Let dry. Hit the parts with primer within 48 hours to prevent flash rusting.
    This is how I prepped my sliders a couple of weeks ago. I am waiting for weather to finish painting them.
    EDIT: This stuff even removes mild rust from metal.
  14. Dec 7, 2016 at 12:34 PM
    #94
    HeavyThumbs
    Phoenix, AZ
    I saw that he had problems, I'm not sure what the issues were. I'd say work methodically on small sections because acetone evaporates very quickly, it's important to make sure you've actually applied it everywhere. I may overdo it when I'm prepping, but I like to make sure what I'm working on has been wet with acetone and then wiped down with a clean rag.
  15. Dec 7, 2016 at 2:11 PM
    #95
    Crom
    Nick
    San Diego, CA
    Millions
    I've painted a lot of metal in projects over the years. Acetone has always worked great. Not sure why the metal In Billy's bumper gave me trouble. It's possible there was a wax applied at one point or another.
    As far as metal prep, it's hard to beat sandblasting. I was quoted $30 for bumper.
  16. Dec 8, 2016 at 5:57 PM
    #96
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I cannot for the life of me figure out how you are fully extending your shocks without having a shackle flip. But for argument's sake, let's assume that you are. And at full stuff you are one inch short of fully compressing the shock. Most shackle flips raise the rear 3/4". Of you do the flip, and strap just before full extension, you will gain an additional 3/4" of travel over what you have now. So is it worth doing the flip? That is your call to make.
    The extra leaf you added to your pack did not add any extra droop. It just increased your spring rate. Once you leaves get back to the arch that they were before install(let's call it static arch) then the extra or lack of extra springs no longer have any effect. And full droop is a bit lower then static arch. Amount of droop is dependent on number of leaves, leaf thickness, spring arch, and axle weight including tire weight.
    I would love to know what your springs measure at full droop from spring eye centerline to top of too spring at center bolt. (I.e. the distance from an imaginary line drawn between the front and rear spring eyes measured perpendicularly down to the top of the top leaf). I would compare it to my measurement. Measuring this way eliminates differences between shackle flip and stock hanger.
    Also an experiment on your part would be great. Unbolt the lower bolt on one shock and droop the rear(with tire on). Compare the fully extended shock eye distance to the mount on the axle. You may find that your shocks are actually limiting your drooo.
    Subway4X4[OP] and Manual man74 like this.
  17. Dec 8, 2016 at 6:10 PM
    #97
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    See? This is where I said F it and just decided to go with it lol!
  18. Dec 8, 2016 at 6:26 PM
    #98
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    How much Bumpstop do you have before you compress the shock to its limits?
    How tall are your bumps is what I'm asking lol.
    bski22, Lilcarkid and Subway4X4[OP] like this.
  19. Dec 8, 2016 at 6:35 PM
    #99
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    :worthless: of your dads 72 scout ii
  20. Dec 8, 2016 at 6:37 PM
    #100
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I have super bumps with u bolt flip. My measurements had me with a half inch of shock travel at full bump, and half inch left at full droop. Reality is a full 12" of shock movement. I need to space my bumos up a tad.
    Nimble9[QUOTED] likes this.
