Subwoofers
Discussion in 'Audio & Video' started by jeddie7811, Oct 4, 2020.
  1. Oct 4, 2020 at 5:25 PM
    jeddie7811
    jeddie7811 [OP] Active Member
    Jacob
    2009 Tacoma double cab
    new grille, headlights, wheels, tires, radio, leds
    Need a subwoofer setup that is really loud on bass, i mean as loud as you can get without taking out the back seats. I am looking for 2 10s or 2 12s i have an 09 double cab please help
  2. Oct 4, 2020 at 6:46 PM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    To quote the old adage, it takes space to make bass.
    How loud is loud? If you have to keep the back seats you may have to lower your expectations.
    robssol likes this.
  3. Oct 4, 2020 at 6:51 PM
    jeddie7811
    Jacob
    like loud enough to where you can feel it in you and the rearview shakes
  4. Oct 4, 2020 at 7:32 PM
    Philrab
    Phil
    What you’ll butt heads with are the following.
    1. Staying behind the factory seats means small boxes, limited airspace, almost certainly sealed enclosures.
    2. The above probably also limits you to subs with limited Xmax, shallow mount subs, less power handling.
    None of that helps you shake eyeballs. I’d look at 2 10’s, because with the limited room you have for enclosures you have a better chance of 10’s matching the enclosure size than 12’s. From experience, a 10 in the right enclosure will outperform a 12 in too small an enclosure.
    Beyond all that, I can’t offer much help. I’ve custom designed and built enclosures that punched out 135-140 dB on as little as 500 watts but the box ate half the hatch. It was a very large ported box, not the kind of thing you’ll fit in the space you’re looking at.
    gunn_runner and robssol like this.
  5. Oct 4, 2020 at 8:45 PM
    jeddie7811
    Jacob
    would a single 12 in a ported box be better than 2 10s?
  6. Oct 5, 2020 at 2:37 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    A friend of mine has a single ported 12”. I have two sealed 10”. We both drive double cab Tacomas. We are running the same amp. Both are tuned for SQ.
    They sound very close. His goes a tiny bit lower. Mine has more punch. Both you can feel and shake the rear view. Both stereos are well more than adequate in terms of volume.
    What you seem to be asking for though sounds a lot like full retard, and it’s hard to decipher what it would take to satisfy you, so it’s hard to make recommendations. It sounds like you want to blow out the windows and frankly, I’m not inclined to help anybody with damaging their hearing.
    There are plenty of 1-2Kw monoblocks out there, and all you have to do is find the right drivers for a box that fits the space.
    All I’ll really say is that if I were in the market for replacement subs in my cabinet, I’d be looking at getting Sundown SD4-10s because that’s about the most beefy shallow(er) mount subs on the market that I’ve seen, and I know they would fit/hit.
    Fattypack likes this.
  7. Oct 5, 2020 at 8:05 AM
    jeddie7811
    Jacob
    yeah i just want pure bass and loudness so should i get 2 SD4-10s, if so what would be the best amp for those
  8. Oct 5, 2020 at 12:45 PM
    danmtchl
    danmtchl Well-Known Member
    Dan
    Bakersfield
    2019 Tacoma TRD Double Cab Sport 4x4
  9. Oct 6, 2020 at 10:10 AM
    jjglass535
    jjglass535 Well-Known Member
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    sd4-10's are a great choice. Got 2 in tiny sealed boxes and they get pretty loud for as small as they are and fit behind the rear seats
  10. Oct 6, 2020 at 5:48 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    SDs are a poor choice for SPL. They sound great, but very low distortion means you can't hear the bottom coming. No bumped back plate means a hard landing when you find it.
    Pick up a single U12, build a proper vented box for it & feed it 2 kilowatts. That should get you where you wanna be.
  11. Oct 6, 2020 at 6:11 PM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    No sealed small box is good for spl but for a slim sub they sure do get loud in my truck. Sure I’ve had way louder but in a huge ported box with 4000 rms.
  12. Oct 6, 2020 at 8:33 PM
    jamlee
    jamlee Well-Known Member
    Jam
    17' QS DCLB OR | 13 gsxr 1000 | 14 QS grom
    My rear view mirror rattles, my mph gauge jumps too when driving. Running 2x 13.5 tw5 with a mr Marv built box
  13. Oct 6, 2020 at 8:34 PM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    Look up jl 13.5 slim. I have one in my 2nd gen. Awesome. Also hit up Mr Marv. He will hook you up with everything you need.
  14. Oct 6, 2020 at 8:36 PM
    jamlee
    Jam
  15. Oct 7, 2020 at 4:01 AM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    A u12 ported is not going behind the seats of a tacoma. Maybe I missed somethimg but thought he wanted something loud that would fit behind the rear seats. Wish I could do a u12 ported but not willing to take up half the truck. Been there with a pair of x 10 and they tore my old frontier up. Every week I had things loosening up and falling apart but man those went so low
  16. Oct 7, 2020 at 4:14 AM
    rob feature
    rob feature Tacos!
    Colorado
    What I read is that he does not want to remove the rear seats. Did not read anything about needing the enclosure behind the rear seats. :)
    I'd definitely do SDs then if they have to go behind the seats.
    01Montaco likes this.
  17. Oct 7, 2020 at 9:49 AM
    jeddie7811
    Jacob
    how will a u12 fit behind the seat
  18. Oct 7, 2020 at 10:13 AM
    jeddie7811
    Jacob
    What about the SA Classic 10s the mounting depth is 6" with a 7.80 magnet diameter. Is there a way i could fit two of those behing my back seat and if so what box wold it be
  19. Oct 7, 2020 at 10:31 AM
    rob feature
    rob feature Tacos!
    Colorado
    It won't without a blowthrough. The OP never said anything about fitting behind a seat...only that you didn't want to remove them.
  20. Oct 7, 2020 at 10:34 AM
    rob feature
    rob feature Tacos!
    Colorado
    I have seen it done here on TW in a 2nd gen - guy's handle is Marine something or another - even ported the enclosure. Box would most likely be custom. I assume there would need to be some modifications to the rear seat backs as well.
