Sudden drop in mpg?
Discussion in '1st Gen. Tacomas (1995-2004)' started by beeser, Jul 28, 2008.
  1. Jul 28, 2008 at 6:19 PM
    beeser
    beeser [OP] Active Member
    My mpg has suddenly dropped to about 15 to 16 from about 20 in the last few months. The only change has been a tuneup and the installation of a new clutch fan for towing, which were both done by a local Toyota dealership. Any ideas what might be causing the change? Oh, the vehicle is a 2004 Tacoma (V6) XCab Prerunner TRD with about 39k miles and has been pampered from day one.
  2. Jul 28, 2008 at 6:32 PM
    Chomag
    Chomag Well-Known Member
    San Antonio TX.
    05 4X4 TRD sport
    Flowmaster Org. 40
    Do you happen to be running an aftermarket oiled air filter by any chance? I know allot of people are saying that oiled filters can clog up the MAF censor which can cause a big drop in efficiency
  3. Jul 28, 2008 at 6:48 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try cleaning the throttle body and changing the fuel filter.
  4. Jul 28, 2008 at 7:34 PM
    beeser
    Thanks for the responses so far. No aftermarket oiled air filter installed. Everything is bone stock. I'll replace the gas filter and clean the throttle body to see if that makes a difference. Any suggestions on cleaning the throttle body? Strange coincidence on the throttle body. It was replaced by Toyota after about 10k miles because it was sticking slightly.
  5. Jul 28, 2008 at 7:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i would get some seafoam deep creep and a tooth brush and clean it really good......it will take afew seconds for the truck to crank afterwards, but it will be fine. you will want to spray the tb really good,and you'll notice alot of carbon buildup come out, scrub it real good, till its nice and shiney and no black residue comes out. also, make sure all the spark plug wires are tight.
  6. Jul 28, 2008 at 7:50 PM
    tarheelfan_08
    tarheelfan_08 Carolina Alliance
    Justin
    North Carolina
    2010 White 4x4 Double Cab Tacoma Short Bed
    Chrome Grill, Chrome accessories(door handles and mirror covers), LEER Super White Cover, Mirrors with Turn Signals, Window Vent Visors, Step Rails, WeatherTech Digital Floor Mats, Mini Maglight Holder, Chrome Bull Bar
    And check your air filter! Also check tire pressure and make sure no extra weight is in the truck or the bed!
  7. Jul 28, 2008 at 8:04 PM
    beeser
    Just so happens I have a can of Seafoam Engine Treatment in the garage. I'll give that a try first for cleaning the fuel system. The air cleaner only has a few thousand miles on it and still looks good. Nothing is in the bed of the truck. I thought there was an outside chance the new fan clutch (orange) would be the culprit but it doesn't seem to raise a flag to anyone.
  8. Jul 28, 2008 at 8:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    just to let you know........for a can of the seafoam that you have, run half the can thru the brake booster line, then put the rest in the tank. cleaning the throttle body is a bit different, as the deep creep is a spray cleaner. just fyi.:)
  9. Jul 28, 2008 at 8:21 PM
    beeser
    brake booster line? I don't understand.
  10. Jul 28, 2008 at 8:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well, any line that feeds the intake, but the brake booster line is better,cause its right there where you can get to it easiest.
    its on the driver side.......look and you'll see a big thich disc looking thing, and a rubber line with a small clamp going to it,and it goes to the intake, thats the brake booster line.
  11. Jul 28, 2008 at 8:34 PM
    beeser
    gotcha ... thanks!
  12. Jul 28, 2008 at 8:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  13. Jul 29, 2008 at 7:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You may also have an O2 sensor going bad. If the Seafoam doesnt help, you may want to consider replaceing them. :)
  14. Jul 29, 2008 at 7:19 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    What type of a towing clutch fan was installed by Toyota ?
  15. Jul 29, 2008 at 7:19 PM
    beeser
    Thanks! I'll add that to the list.
