Sufficient gear ratio for 285/18s & 3in lift?
Discussion in 'Technical Chat' started by Blkturbo!, Apr 25, 2011.
  1. Apr 25, 2011 at 10:48 PM
    Blkturbo!
    Blkturbo! [OP] Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    So if the original gear ratio for the 08 sport is 3.73, then what would be a sufficient choice in ratio to compensate for the addition of 3in lift and 285/65/18 TRAIL grapplers (heavy combo!)?
    Do you think 4.10s would do it? And what's the next ratio choice after that anyway?
    thanks!
  2. Apr 26, 2011 at 7:14 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I'm running stock gear with that tire size and I don't have any issues.
  3. Apr 26, 2011 at 7:28 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    i personally am going to go w/ 4.10s. i am personally running 33" TGs w/ the 3.73 gears. just fine for my driving, but the 4.10s will get me back to stock and put me in a little better powerband.
  4. Apr 26, 2011 at 9:04 PM
    Blkturbo!
    Sean
    Henderson, NV
    Hmmm, maybe so but my TRAIL grapplers are FAWKIN HEAVY (10ply whores) and I pull my 800lb jetski in the hills of Vegas and elsewhere, so i'd like to keep some of that decent factory holeshot.
    Plus, the trail grapplers run larger than what a tire calculator will tell you. They are damn near 12in wide and 32.5+ in tall.
  5. Apr 26, 2011 at 9:06 PM
    Blkturbo!
    Sean
    Henderson, NV
    What ratio are you running? Im thinking 4.56 would be overkill on the hwy.
  6. Apr 26, 2011 at 9:07 PM
    Blkturbo!
    Sean
    Henderson, NV
    4.10 is the very next choice over the factory 3.73, correct?
  7. Apr 27, 2011 at 7:31 AM
    Bama_TACO
    Winfield, AL
    My Terra Grapplers are Load Range E and are heavy too, but if I was towing with a lot of hills I would go with a lower gear too. My driving is all interstate and fairly flat.
  8. Apr 27, 2011 at 7:37 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    4.10s are hard to come by from what i heard, 4.56's are what im going to eventually run they arent to bad on the highway.
  9. Apr 30, 2011 at 10:10 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    alot of the first gen tacos came with 4.10s, plus the tundras, sequoias, came w/ them too.
