Suggested Maintenance on 1996 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by oldtaco, Jul 3, 2011.
  1. Jul 3, 2011 at 11:52 AM
    oldtaco
    oldtaco [OP] New Member
    Burlington, VT
    96' Tacoma 6cyl Manual
    Running Boards Bug Guard Sony Sound Piece O crap Tool Box Bed Liner
    I just bought a 1996 manual 6 cycl tacoma with 228,000 miles. It runs like a champ. No noticeable problem. A couple aesthetic things of course. However, I was wondering if anyone suggested typical maintenance to perform. I was going to change most of the fluids and maybe change the thermostat. Any ideas?
  2. Jul 3, 2011 at 12:00 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    I'd look into replacing ALL of the coolant hoses before they fail. Otherwise one fails, you ifx it, another one fails, you fix it, etc. Nobody ever replaces the small misc ones until they fail.
  3. Jul 3, 2011 at 12:01 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Spark plugs.
  4. Jul 3, 2011 at 4:33 PM
    jblair
    jblair Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    don't those need the timing belt done?
  5. Jul 3, 2011 at 5:14 PM
    ERG80
    ERG80 Newb
    TN
    1997 T100 & 1996 FZJ80
    Do you know any of the maintenance history? If not I'd start with these basics to get a good baseline.
    Toyota maintenance Intervals:
    http://smg.toyotapartsandservice.com/guides.php
    30,000 mile / 24 month maintenance items
    These items also apply to the 60K, 90K, and 120K maintenance intervals.
    REPLACE:
    SERVICE:
    INSPECT:
    • Drive belts
    • Ball joints & dust covers
    • Brake lines and hoses
    • Brake linings/drums & brake pads/discs
    • Fuel lines, connections, and vapor vent system hoses
    • Fuel tank cap gasket
    • Steering gear box, linkage, and boots
    • Exhaust pipes and mountings
    ADDITIONAL ITEMS FOR SPECIAL OPERATING CONDITIONS:
    Testing the Positive Crankcase Ventilation (PCV) valve
    Cleaning the Mass Air Flow (MAF) sensor
    Cleaning the Throttle Body
    Changing the Fuel Filter
    30/60/90/120K Walkthroughs
    http://www.4x4wire.com/toyota/mainte...a_4runner_30k/
    http://www.4x4wire.com/toyota/mainte...ntenancep2.htm
    http://www.4x4wire.com/toyota/mainte...ntenancep3.htm
    http://www.4x4wire.com/toyota/mainte...ntenancep4.htm
    http://www.4x4wire.com/toyota/mainte...ntenancep5.htm
    more info: http://www.tacomaworld.com/forum/1st-gen-tacomas/156943-1st-gen-tacoma-buyers-guide.html
  6. Jul 3, 2011 at 5:21 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Let's see some pics! I love my 96!
  7. Jul 3, 2011 at 8:59 PM
    saltbranch
    saltbranch Well-Known Member
    Tx
    1996 2.4,2wd,5spd, stock, 250k
    Another thing to look at would be the ball joints, mine failed at 230k or so on the passenger side, then around 260k on drivers side. Both time they cut loose I was up at our property and both time the frontend just hit the dirt. The passenger side ones caught me by surpised, no noise,squeaking just driving along and frontend hit the ground....driver side I knew was going bad but kept driving it cuz at that time I was driving on ranch only, not on the road with it.
  8. Aug 20, 2011 at 4:35 PM
    oldtaco
    Burlington, VT
    Did all the suggested stuff and some more and just made it 1900 miles from CO to VT in 2 days. Thanks
