Suggestions on sealing holes in Leer cap
Discussion in 'Tonneau Covers, Caps and Shells' started by briangig, Jun 3, 2019.
  1. Jun 3, 2019 at 8:00 PM
    briangig
    briangig [OP] Well-Known Member
    NH
    06 SR5 DCSB
    I have a Leer fiberglass cap I am changing the rack on and wrapping (vinyl). The new tracks I am putting on are a bit shorter than what was up there, so I am going to have 4 holes total I need to seal, and be able to go over with vinyl. The holes are about 1/4".
    My train of thought is to somehow back the holes from the inside and fill from the outside with some type of epoxy I can easily smooth out without sanding or otherwise doing too much damage to the paint. Any ideas would be much appreciated!
  2. Jun 4, 2019 at 11:40 AM
    synaps3
    synaps3 Wag more bark less
    Dave
    Atlanta, moving to NM in April
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    The right way to do it is fiberglass and epoxy, but that takes a lot of labor, sanding, and cost. These toppers are constructed out of fiberglass similarly to a boat, so you can google fiberglass boat repair or stop by a West Marine or similar. In all honesty though, I think that's a waste of time on a truck.
    The next best way to do it would be to use bondo. You can get bondo from any automotive store or even home depot. Typically you sand bondo smooth and repaint, but it's fairly workable and easy to get smooth before sanding if you take your time and use a plastic putty knife, cleaning around the hole afterwards.
    The easiest is to just use a good silicone caulk, but you will be able to see that through the vinyl wrap.
  3. Jun 4, 2019 at 8:12 PM
    briangig
    NH
    06 SR5 DCSB
    How could I have forgotten about bondo! I think that may be the winner.
  4. Jun 8, 2019 at 6:12 PM
    tslick
    tslick Well-Known Member
    Tom
    Yuma.AZ
    2002 Tacoma 4X4
    Working on it
    This is the best but expensive for a couple small holes. It will stay good in tube though.
    https://www.amazon.com/West-Systems...tem+610+epoxy&qid=1560042638&s=gateway&sr=8-3
  5. Jun 10, 2019 at 6:22 AM
    briangig
    NH
    06 SR5 DCSB
    If anyone comes across this in the future with the same issue, I ended up just getting longer tracks to cover the holes. But I think either bondo or that West Systems epoxy would have worked fine.
