Sun Visor swap?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBeasty, Jun 11, 2008.
  1. Jun 11, 2008 at 9:03 PM
    JBeasty
    JBeasty [OP] Member
    Northern California
    08 standard cab, 2.7L, 4 sp auto.
    None yet
    I have the standard cab base model 08 Tacoma - with the sun visors that have no extension for when you are using them to block sun coming in the side window. I was thinking I would like to install one of the visors from one of the upgraded models, like the access cab/double cab models. Anyone here try this? Are they the same size? - I eyeballed it at the dealer, and they look interchangeable . . .
    Thanks, JB
  2. Jun 12, 2008 at 12:33 AM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    There's no reason that they shouldn't fit. All of the windshields are the same.
  3. Jun 12, 2008 at 9:25 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I have a set if you're interested. Grey interior. Just cover the cost of shipping and they're yours.
    Jlarios956 likes this.
  4. Jun 12, 2008 at 2:14 PM
    JBeasty
    JBeasty [OP] Member
    Northern California
    None yet
    We're talking about the flip down visors, mounted above the windshield right? Do yours have the little plastic extension that you can pull out when trying to block the sun coming through the side window?
    My concern was that the trucks with these, also usually have additional "stuff" in the ceiling console (outside temp gauge, garage door remote. etc.). I was wondering if the console is then wider, or different in some way - changing the shape or length of the visor. But again, the space for the visor "looks" about the same. I suppose I should go back to the dealer, with my visor in hand, and hold it up to the one at the dealer.
    IF it is the same, YES!, I would gladly take yours. Just curious, why are you getting rid of yours?
    Thanks, JB
  5. Jun 12, 2008 at 2:24 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Where he'll be driving his truck, sun visors are for sissies!
  6. Jun 12, 2008 at 5:25 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    I have a regular cab SR5, and it has the upgraded visors as part of the SR5 content, and I really don't like them as I do in our other vehicles due to the roof line that tapers down so much in the front. If I reach up and over to slip an envelope of similar under the passenger side visor, my head hits the driver's side one since it is so thick. Someone in the past had stated he changed his to the thinner base models and liked them better. I would rather have had the mini roof console of the AccessCab with the additional dome/map lamps and some sun glass storage than the visors. Slightly off topic a little, but I wonder also how much the sloped roofline helps the aerodynamics if any. The online Toyota info does state the drag coefficient, but I don't know the specs of the 1st generation models.
  7. Jun 12, 2008 at 5:28 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    To answer your question; which I did not do directly in my above post, the visors out of a vehicle with a roof console will swap out with a vehicle without a roof console.
  8. Jun 13, 2008 at 7:02 AM
    mjp2
    NJ
    PM sent. :)
  9. Jun 29, 2008 at 12:40 AM
    JBeasty
    JBeasty [OP] Member
    Northern California
    None yet
    Just wanted to say, for any one following this thread: you CAN switch them. mjp2 gave me his and they swapped out nicely. They are working well for me so far. A little heavy and 'jiggly', but maybe my thin ones jiggled and I didn't notice. And they block the sun I was getting on the side of my face every day on the way to work! Thanks again mjp2!!
