Sunroof Seal ??
Discussion in '1st Gen. Tacomas (1995-2004)' started by bellassaiw10, Dec 25, 2011.
  1. Dec 25, 2011 at 5:38 PM
    bellassaiw10
    bellassaiw10 [OP] Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Sunroof has been leaking and I need to find a new seal but can't find one online :confused: anybody know where I can find one ??
  2. Dec 25, 2011 at 5:44 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
  3. Dec 25, 2011 at 6:08 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    factory sunroof?
  4. Dec 25, 2011 at 6:17 PM
    bellassaiw10
    Currituck NC
    Yeap, and already tried rock auto no luck there or carpart
  5. Dec 25, 2011 at 8:46 PM
    bellassaiw10
    Currituck NC
    I don't need carpet or vinyl I need the weather stripping along the inside of the sunroof ill give them a call tomorrow
  6. Dec 26, 2011 at 2:56 PM
    bellassaiw10
    Currituck NC
    Happens to the best of use, heading to the stealership tomorrow to see what the damage will be
  7. Dec 26, 2011 at 5:23 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Factory Sunroof??? :confused:
    My dad's 87 had an aftermarket sunroof in it and it leaked like a sieve from the day he bought it to the day he sold it.
    No matter what gasket, sealant, foam, etc....it would leak.
  8. Dec 26, 2011 at 7:39 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Mine leaks when the temp goes from snowing and frozen to warm and wet. The ice builds up and moves the rubber then melts and leaks in. I am going to swap out the seal and see if it helps.
    Ive had 5 Preludes (88, 89, 90, 91 and 99) and none of the sunroofs had a problem because when they leaked (which all sunroofs do) there was an inner channel that caught the water and drained it out the rear wheel well. Totoya's press-fit seal will probably never work perfect because the rubber expands and contracts with temperature allowing water in. Blah. One of my only complaints about the Taco.
  9. Dec 26, 2011 at 8:08 PM
    bellassaiw10
    Currituck NC
    Its never leaked until about a few months ago, took the headliner out and all the drains are clear so I'm guessing its the seal has finally gone bad on it, other then that its perfect, and yes its a factory sunroof
  10. Dec 26, 2011 at 8:20 PM
    TacoMX
    Jonathan
    Deltona, Florida
    well, good thing its factory. Probably will be fine once you get a new seal. Aftermarket units are notorious for leaking.
    You're lucky...factory sunroof if a pretty rare option on these trucks.
  11. Dec 26, 2011 at 8:37 PM
    Jib Bandits
    Jib Bandits Pork eating crusader. An "infidel".
    Ari
    Cedar Fort, UT
    06 Access TRD Sport
    Red devil horn emblem, All-Pro Expo leafs, Fox shocks, K&N CAI, aFe throttle body spacer, Flowmaster american thunder dual exhuast, Defender roof rack, Hell Bent steel level kit, Rigid Dually LED lights, smoked halo headlights, smoked LED taillights, Cobra CB, red badge mod(+30 HP), Spider-Trax wheel spacers!
    You could try squeezing in some silicone, it might work a lil better.
  12. Dec 26, 2011 at 8:38 PM
    bellassaiw10
    Currituck NC
    Yeah they said they'll call me back on pricing, ill lay a bead of silicone down with the new one for extra protection, and yeah i like it even tho it just pops up its still nice
  13. Dec 26, 2011 at 8:42 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I love mine. Even for just the sunlight factor. When I get in other vehicles I always find myself thinking "why is it so dark"?? haha
  14. Dec 27, 2011 at 3:22 PM
    bellassaiw10
    Currituck NC
    Yeah I've got mine tinted so it doesn't do much lol but the seal was only 35 bucks from th dealer should be here thursday
