Super Ultimate 3rd Brake Light Build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Nov 30, 2017.
  1. Apr 15, 2019 at 11:18 PM
    #2201
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Harbor freight lights won?
    NoOne likes this.
  2. Apr 15, 2019 at 11:26 PM
    #2202
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
  3. Apr 15, 2019 at 11:38 PM
    #2203
    MoofTaco
    MoofTaco Well-Known Member
    Joe
    Roseville, CA
    2017 Silver Tacoma TRD Sport 4x4
    Won’t lie It was a slight pain to fish through using the wires wrapped together as they come from BD. I got some through that way by just forcing It but after two I just stripped away some of the outer jacketing and just fished the power/ground wires themselves until I could grab them behind the housing then pulling wire through with jacketing was easier. But in all It was a pretty simple install. Thanks for great product the housing fits the BD lights so well. Very happy :cheers:
  4. Apr 16, 2019 at 12:40 AM
    #2204
    MaukatoMakai4V6tacoma
    MaukatoMakai4V6tacoma Well-Known Member
    Eric
    2016 4V6 DCLB TRD Sport heavy hitter
    I’ll be keeping an eye out for that. Thanks
  5. Apr 16, 2019 at 7:16 AM
    #2205
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    Can you share how to do this?
  6. Apr 16, 2019 at 8:20 AM
    #2206
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Others have posted to this, but I'll give the quick rundown:
    1) Open rear doors and pull down on the door seal where it overlaps the roof and rear upper areas.
    2) Pop open the SRS covers on the rear upper pillars and remove the single bolt behind it.
    3) These panels come out by simply snapping in place. They have two lower tabs that insert into hidden slots in the back of the lower panel. Pull out enough that you can disengage these to remove and move this panel out of the way.
    4) Remove the access panels on the coat hooks and ohshit handles. Remove the metal insert (compress together and pull outward). Remove these items and put to the side.
    5) The headliner is now lose enough to drop down and give you sufficient access. for the rest of the steps.
    6) Open the rear sliding window.
    7) Get up in the bed and reach through the open window and into the gap between the headliner and the roof itself.
    8) The two nuts (deep socket, 1/4 drive works well) are inside a round hole, right where the pictures show they are. The long stud will protrude and guide you/the socket.
    9) Remove and begin the glorious process of cleanup/install/re-assembly.
    10) Cold beer - be proud of yourself for not completely screwing that up.
  7. Apr 16, 2019 at 8:55 AM
    #2207
    tomgru
    Thomas
    PNW
    2021 TRD Pro
    F'n brilliant... thanks.
    I may start with a beer as well :)
    Boomer3731 and AZJuice like this.
  8. Apr 16, 2019 at 9:24 AM
    #2208
    AZJuice
    AZJuice Well-Known Member
    Juice
    Arizona
    16 Taco DCLB Sport 4x4
    2 sneaky clips hiding in Back seat area above light too.
  9. Apr 16, 2019 at 10:37 AM
    #2209
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Dome light? I didn't mess with that. Not sure where else you would be referring to.
  10. Apr 16, 2019 at 10:41 AM
    #2210
    buntcake
    buntcake Well-Known Member
    Booboo
    2020 TRD OR Cement
    Anybody got a line on a good deal for BD lights?
  11. Apr 16, 2019 at 10:44 AM
    #2211
    AZJuice
    Juice
    Arizona
    Yes. For me it allowed me a few more inches of wiggle room.
  12. Apr 16, 2019 at 10:45 AM
    #2212
    stiles88
    stiles88 Well-Known Member
    Seattle (Bothell WA)
    2020 GLE 350, 2008 FJ
    @memario1214
    uploadadventure likes this.
  13. Apr 16, 2019 at 11:03 AM
    #2213
    brentano
    brentano Well-Known Member
    2017 TRD OR AC SSM
    I've got a 3rd gen Access Cab. I will control the middle (white) light of a @mesojdm BD3 as a cargo light using a double cab "Off-Door-On" switch that I will be installing per this thread:
    https://www.tacomaworld.com/threads...s-using-double-cab-cargo-light-switch.436440/
    This will require that I install and route the switched hot cargo light wire from the relay (IE1-pin 14) up to the BD3 (the wire is absent in an AC). Any advice on the routing of this wire up to the headliner position would be appreciated.
  14. Apr 16, 2019 at 11:07 AM
    #2214
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    I sent him a PM as well.
  15. Apr 16, 2019 at 11:38 AM
    #2215
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Route it along under the door sill cover plates with the factory wire all the way to the C-pillar then do what the others are doing to drop the rear portion of the headliner, so you’ll have the C-pillar plastics apart and can then run the wire up to the roof and over to the 3rd brake light, securing your wire along the way.
    It’s the same routing scheme I’ll be doing on my 2nd gen.
    Door sill plates are just snapped in place and pop off.
  16. Apr 16, 2019 at 11:39 AM
    #2216
    stiles88
    I think he might be out of town this week, but he will definitely get back to you. I got my lights from him and the customer service he provided was top notch.
    MoofTaco, buntcake and cruiserhead like this.
  17. Apr 16, 2019 at 3:26 PM
    #2217
    buntcake
    Booboo
    2020 TRD OR Cement
    Cool I'll reach out to him, thanks for the info!
  18. Apr 16, 2019 at 3:41 PM
    #2218
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    I’m still looking for one... willing to up my game:
    Send this to me via Priority Mail and I will send you back via Priority Mail a MESO Ultimate Dome (White).
  19. Apr 16, 2019 at 3:46 PM
    #2219
    stiles88
    I'll be cutting mine off this weekend and I can send it to you if you want to cover the shipping. No need to send me the Ultimate dome light for something I am planning on throwing away.
    Nv2056 and NoOne[QUOTED] like this.
  20. Apr 16, 2019 at 10:47 PM
    #2220
    Naughty
    Naughty Well-Known Member
    Chicago
    @Taylor@KC HiLiTES any word on weather the 30mm mini cyclones will be a thing?
