supercharger and header on the way, what next...
Discussion in 'Performance and Tuning' started by waldonbuddy, Apr 5, 2008.
  1. waldonbuddy
    waldonbuddy [OP] New Member
    Alabama
    2.4l, battery under bed, supercharger, full length header, off road pipe........
    can I buy for my 2.4l 2002 Taco to boost performance? Can I install a bigger mass air meter and throttle body without messing up the computer?
    Also, can I just weld a bung to install the secondary O2 sensors to my offroad pipe to keep from getting a CEL {off road pipe is homemade, since I own a tubing bender}?
    thanks, Mike U.
  2. TACOROCK
    TACOROCK Well-Known Member
    FAYETTEVILLE NC
    06 TACOMA LIFTED
    URD SUPERCHARGER 80MM PULLEY, DOUG THORLEY LONG TUBE HEADERS, MODIFIED Y-PIPE, TRUE DUAL EXHAUST MAGNAFLOW 2 IN 2 OUT, PRO COMP 6" LIFT, WIDEBAND 02/FUEL SENSOR, AVIC D3, 2 PIONEER SUBS ON A MEMPHIS 1200 WATT AMP RMS, DIY MOD FOR ALL INTERIOR SPEAKERS FULL TINT, LEER CAMPER, EURO LIGHTS, BILLET GRILL, BULL BAR WESTIN RUNNING BARS, AIR HORN, AND A RADIATOR POPPER
    ecu upgraded chip!!!
  3. waldonbuddy
    Alabama
    where can I buy a chip? thanks, Mike
  4. 2rz_Taco_Sr5
    2rz_Taco_Sr5 Cracker
    Tampa
    mini ext cab sr5
    6" fabtech, axle flip, exhaust, other stuff but to lazy to type
    to use a bigger maf sensor like a mustang one which ive seen done before, you would need a urd maf calibrator to tune it to your truck.... now if you have some sort of fuel management for that charger you got then use that if not a would recomend getting the calibrator because it will give you quite a bit of power and be safer for your motor :thumbsup:
    for the secondary o2 id recomend the empire offroad o2 simulator it allows you to completely remove the second o2.
    no way to alter the stock toyota ecu its rom and unchangeable, you need a piggyback like urd or splitsecond or a standalone :thumbsup:
  5. 2rz_Taco_Sr5
    Tampa
    mini ext cab sr5
  6. waldonbuddy
    Alabama
    Actually the supercharger kit Ive ordered has an extra injector and ecu chip that comes with it.
    Im going to call LC Engineering and find out if I can move up to a bigger injector in the future if I go with more boost.........thanks, Mike
  7. 2rz_Taco_Sr5
    Tampa
    mini ext cab sr5
    nice man well yeah to be able to use a larber maf you just need a way to tune it thats all ;)
