supercharger bs thread.....cuz all the other blower threads turn to bs anyhow
Discussion in 'Performance and Tuning' started by Justus, Jan 18, 2016.
  1. Mar 14, 2016 at 7:07 AM
    #201
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah that was the exact same thing that was happening with mine. I almost felt as if it was slipping. It was starting to make me nervous.
  2. Mar 14, 2016 at 7:50 AM
    #202
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    More engine torque. More weight. What happens to a stock clutch on the manual transmission? Similar difference.
  3. Mar 14, 2016 at 8:01 AM
    #203
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeah yeah yeah.
    12TRDTacoma likes this.
  4. Mar 14, 2016 at 11:42 AM
    #204
    ThomasMore66
    Dallas/Fort Worth & Durango
    Mine does this now. Good to know there is a computer fix.
    12TRDTacoma[QUOTED] likes this.
  5. Mar 14, 2016 at 11:47 AM
    #205
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's a scanner made by Autoland. The VeDiS 2.
  6. Mar 14, 2016 at 12:00 PM
    #206
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Lol. Yeah. It's not a cheap one. You could probably have a shop do it for you given that they have a high quality scanner for not all that much. A cheapie scanner will definitely not do the trick as those only cover basic functions. I really had to search deep in the scanners functions to find it. Disconnecting the battery and clearing the PCM memory will not cut the trick though.
  7. Mar 14, 2016 at 12:41 PM
    #207
    12TRDTacoma
    Rob
    Concordia
    Boosted
  8. Mar 14, 2016 at 8:15 PM
    #208
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Your handheld? No it most likely (actually highly likely) will not.
  9. Mar 16, 2016 at 9:55 AM
    #209
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    100 lbs should be worth about a tenth or so in the 1/4.
  10. Mar 16, 2016 at 3:43 PM
    #210
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I say leave them. Thats what youll be running any other time on the street.
  11. Mar 16, 2016 at 7:31 PM
    #211
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    I wonder if I have any needle bearings on the back of my SC.
  12. Mar 16, 2016 at 9:29 PM
    #212
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Looks like imma have to remove the old grease from the back bearings and out new in. I just used the syringe and put some in there.
  13. Mar 17, 2016 at 12:11 PM
    #213
    ThomasMore66
    Are you suggesting that manually shifting will help the tranny learn in lieu of a reset? I have noticed that my 4-5 shift is better when I do it manually. The computer adjusting shifts is new to me.
  14. Mar 17, 2016 at 12:20 PM
    #214
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Mar 17, 2016 at 2:17 PM
    #215
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I used to smack the auto over in to 4 when I wanted to downshift and haul ass. then shift it over to D once I got the power I wanted. It made me feel like I had a manual but I never noticed faster 5-4 shifting if I just stepped on it. Although, I had a lead foot from day one in both trucks, so my ECU probably was already used to faster shifts
  16. Feb 6, 2020 at 9:30 PM
    #216
    riven29
    riven29 Well-Known Member
    1995 Maroon Tacoma
    Hey guys im hoping someone can help me with this, i just got a 1st gen (grey) TRD supercharger (for $500) but i know that it wont work on my 95 tacoma without either and ECU swap to a 97' or installing URD 7th injector and tuning? Is that correct? And does anyone have a part number for the correct 97' ecu or have one they would be willing to sell? Thanks!
  17. Feb 7, 2020 at 5:45 PM
    #217
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    @riven29
    You will need the 97 ecu regardless. You need it to have the same transmission type (auto or manual) and the same drive output (2wd or 4x4). Mine was 5vz/auto/4x4 so that's what I got. That is how you determine which ecu code you need. Dont get the 98, different pinout.
    I picked one up at a local junkyard. They even let me test it on my truck first. (Not all will).
    Torspd likes this.
