supercharger bs thread.....cuz all the other blower threads turn to bs anyhow
Discussion in 'Performance and Tuning' started by Justus, Jan 18, 2016.
  1. Feb 21, 2016 at 3:44 PM
    #101
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Everyone seems to promote the AFE as the intake to use with the soopercharga; I'm using an AFE myself.
    RogueTRD[QUOTED] likes this.
  2. Feb 21, 2016 at 4:28 PM
    #102
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    AFE all the way, but are you still using the stock airbox? Ditch that sumbitch, asap!
  3. Feb 21, 2016 at 4:47 PM
    #103
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    Yeah, I haven't decided on if I can run a CAI with my ARB compressor under the hood. I'm gonna have to do some measuring.
  4. Feb 21, 2016 at 8:21 PM
    #104
    ThomasMore66
    Dallas/Fort Worth & Durango
    Wait...what?! You have all sorts of issues. I don't know where to start.
  5. Feb 21, 2016 at 8:43 PM
    #105
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    I'm using the stock TRD Filter/airbox, Talk to me Goose...
  6. Feb 21, 2016 at 8:54 PM
    #106
    VolcomTacoma
    Jeff
    NorCal
    A good boxed CAI really makes noises more. Plus a bit more HP. Id say first on the list would be a CAI, less restrictive, more air =moar hp. And then go with a smaller pulley. Then some sort of exhaust and if you're really feeling frisky you can do the rest of the exhaust mods
    Biscuits likes this.
  7. Feb 29, 2016 at 12:35 PM
    #107
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Seems you found a new use for your s/c. Fun multiplier.
  8. Mar 2, 2016 at 11:21 AM
    #108
    RunsGuns
    RunsGuns Well-Known Member
    Sam
    Colorado
    Previously SC LT ‘12 taco. ‘95 FZJ80.
    Im still running the stock airbox. Thinking about a snorkel. Any things to consider? I wanna go fast through rivers.
    And i saw that legend dude a while back, he got real pissy when i questioned him. I didnt know he turned off the comment section. What a fag. As for the hick voice, that was bad but his lisp made it unbearable.
  9. Mar 2, 2016 at 11:30 AM
    #109
    RunsGuns
    Sam
    Colorado
    WOODEX M.E. likes this.
  10. Mar 2, 2016 at 11:32 AM
    #110
    RunsGuns
    Sam
    Colorado
    The guy everyone was ragging on about his 400hp tacoma. He took all his videos down bc people were giving him hell.
  11. Mar 2, 2016 at 12:55 PM
    #111
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Glad he took it upon himself to remove his bullshit from the internet. I will sleep easier now knowing the internet has, for once, won a battle against idiocy. Thanks for positing that video!
    Lord Helmet and RogueTRD like this.
  12. Mar 2, 2016 at 4:43 PM
    #112
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It take A LOT to get there with the M90. The cost will be more than that of a turbo kit. Especially now.....
  13. Mar 3, 2016 at 11:29 AM
    #113
    WOODEX M.E.
    Corey
    Maine
    The LEGEND! don't need nitrous, his 400+ HP comes from a shot of EGO
    Lord Helmet, Torspd and RogueTRD like this.
  14. Mar 3, 2016 at 1:21 PM
    #114
    6xchamps
    6xchamps Well-Known Member
    Fuquay Varina NC
    2015 AC
    I've gotta be honest, I hate that there is an entire group of people who aren't familiar with THE LEGEND
    Torspd likes this.
  15. Mar 3, 2016 at 6:11 PM
    #115
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Tanabe gauges FTW :D
    Torspd likes this.
  16. Mar 3, 2016 at 6:27 PM
    #116
    Lord Helmet
    Nick
    '24 X3 M40i
    :laugh:
  17. Mar 3, 2016 at 6:28 PM
    #117
    Lord Helmet
    Nick
    '24 X3 M40i
    How come you don't use the Speedhut gauges?
  18. Mar 3, 2016 at 6:34 PM
    #118
    Lord Helmet
    Nick
    '24 X3 M40i
    If it works for a Dodge then it should work on the Taco :D
    As you can see, plenty of room :laugh:
    WOODEX M.E. and 6xchamps like this.
  19. Mar 3, 2016 at 6:36 PM
    #119
    Lord Helmet
    Nick
    '24 X3 M40i
    Overkill you think?
    :laugh:
  20. Mar 3, 2016 at 6:54 PM
    #120
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    If you decide on the dual innovation AFR gauge, let us know how you like it. I'm looking into for my slowmaro.
