supercharger bs thread.....cuz all the other blower threads turn to bs anyhow
Discussion in 'Performance and Tuning' started by Justus, Jan 18, 2016.
  1. Mar 7, 2016 at 11:11 AM
    #161
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    I sharpen my pencils for college with my SC
    Torspd likes this.
  2. Mar 7, 2016 at 11:22 AM
    #162
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Damn, I was hoping for some other flash via OBD II like Toyota does.
  3. Mar 7, 2016 at 11:22 AM
    #163
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Too bad I never got a welder years ago. Could have been making turbo kits and selling them already.......
    Lucario Runner likes this.
  4. Mar 7, 2016 at 11:22 AM
    #164
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Wonder if they're throwing in a UCON or just the overpriced BDT
  5. Mar 7, 2016 at 11:26 AM
    #165
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Meh, I like the roots blower for offroading. I'd think a custom turbo system would be a little more prone to issues from abuse in dusty, wet, and muddy conditions.
    RogueTRD likes this.
  6. Mar 7, 2016 at 11:30 AM
    #166
    VolcomTacoma
    Jeff
    NorCal
    Yeah I also like the low end power. And yeah yeah @Torspd, I know your shit boosts at like 2k rpms lol, but I bet most off the shelf turbos dont start building hp and torque until youre higher up in the rpms. Or am I totally wrong? I dunno. if I was gonna do it again I'd probably just go with a URD SC and get someone to make me a wire harness for UCON.
  7. Mar 7, 2016 at 11:57 AM
    #167
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Odds are that if you snap something due to POWAH you were going to do it with or without the supercharger.
    I'm talking about the risks if something goes wrong. If the engine and roots blower take in a little water or dirt they can survive and cleaning is fairly simple. Plus the only source is from a fairly short intake so you can plan on how to mitigate that from happening easily. With all the extra intake tubing on a Turbo setup, not to mention to complexity of the turbo and exposure of the blow off valve, the risks are a bit higher that something could go wrong without you noticing until it's too late.
    It's not impossible to deal with, but it's a nice feature of the roots that it's so darn simple.
    Torspd likes this.
  8. Mar 7, 2016 at 12:16 PM
    #168
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    A tough change is better than an overboost grenade to some, and not to others :).
    I get what you are saying but the roots is the simpler less likely to cause catastrophic damage system. That's why they are so common as factory endorsed upgrades over turbo kits in general. Then again, the S/C has it's own limits that a turbo can go well past.
  9. Mar 7, 2016 at 12:16 PM
    #169
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Turbo engined rally cars. All I have to say.
    @VolcomTacoma , it depends on a lot of variables. At the top of that list is properly sizing the turbo to the application, with regards for necessity of intended use.
  10. Mar 7, 2016 at 12:17 PM
    #170
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    You just a high pressure gun to wash your engine?
  11. Mar 7, 2016 at 12:20 PM
    #171
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Turbo rally cars for sure have things setup right for what they do, but comparing a rally car to may rig is like comparing a NASCAR to a stock V8 Mustang. The longevity of the entire rig and the expectations for maintenance are completely different.
  12. Mar 7, 2016 at 12:22 PM
    #172
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Do you guys not have a local wash with a low pressure engine cleaner setting on the pressure washer? Hose it down with that, which is basically per use simple green, and then wash it off with the pressure washer from a distance like @Rock Lobster says.
    I try not to wash at home because I can never keep the materials in good enough shape over time to make it worth it.
  13. Mar 7, 2016 at 12:38 PM
    #173
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    I been doing high pressure when I first owned her. I do keep a fair distance away from my engine with the high pressure. But I will keep simple green in mind real soon.
  14. Mar 7, 2016 at 12:40 PM
    #174
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Most of the time I don't see that option at some car washes. But I'll keep my eye out for that today. Even though the engine is gonna get dirty again this weekend.
  15. Mar 7, 2016 at 12:41 PM
    #175
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Whole lot cleaner than mine. I'm gonna have to buy a scrubber especially for my engine.
  16. Mar 7, 2016 at 12:49 PM
    #176
    VolcomTacoma
    Jeff
    NorCal
    I try not to clean my engine at car washes because usually 100% of the time I didn't park it at the car wash for an hour to let everything cool down. I know most people say 'it's fine, its fine, what about when you go through a puddle or some rain or something' and I say, hot metal+cold water is never a good mix, period. Anyhoo, I have a pressure washer at the house, like RL said, I dump some Simple Green in the soap dispenser thingy on the washer and soap the engine bay down really good, and then let it sit for a few minutes, then just turn on the HP jet and clean everything. Just don't spray directly on to anything electronic, or at least hold the jet on electronic stuff, and you're fine. THEN turn the engine on and let it dry itself off :D
    Torspd likes this.
  17. Mar 7, 2016 at 1:16 PM
    #177
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The overall point simplicity aside, is that it can be done and work in harsh off road environments. Look at @MadTaco461 's build. He off roads the heck out of his truck. At speeds and over dunes. Inherent failing points of any style of F/I adder just need to be addressed for the conditions it'll be in. (As is the same for a truck build.) First and foremost is heat abatement.
    MadTaco461 and Sterdog[QUOTED] like this.
  18. Mar 7, 2016 at 1:17 PM
    #178
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Should get some others to join. :thumbsup:
  19. Mar 7, 2016 at 1:29 PM
    #179
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    True enough. I never said it was a bad idea to turbo an OR truck of any sort. Just, like you said, that the roots blower has some simplicity advantages in those situations that some people might value.
    Torspd[QUOTED] likes this.
  20. Mar 7, 2016 at 1:42 PM
    #180
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    When you racing?
