Supercharger Help
Discussion in 'Performance and Tuning' started by Heschke, Apr 16, 2011.
  1. Apr 16, 2011 at 11:38 AM
    Heschke
    Heschke [OP] Well-Known Member
    Arroyo Grande, CA
    Tacoma PreRunner
    Hey guys I just bought a used supercharger this week for my 07 4.0L V6 w/ 93k, and I have a few questions if you could help me out. It came with everything except injectors and I know stock ones will not do, I was told URD makes some but I could not find any for the 4.0L V6? Does anyone know where I can find some and what price they run at? Also will this thing work with the stock intake or do I need an aftermarket cai? Will it run on regular or only premium gas? I am going to install myself so any tips on the install will be a big help. Thanks!
  2. Apr 16, 2011 at 11:51 AM
    outlaw7
    outlaw7 Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    you need premium fuel in it always after the blower is installed. you can try to find someone who has a set of the trd 425 injectors or you could try to order new ones from toyota. those will be all you can run unless you have an x-1 tuner or equivalent. there is an awesome write up on the trd install on here somewhere give me a few mins ill look around for it.
  3. Apr 16, 2011 at 11:53 AM
    xroller
    xroller Blowin by em sideways
    X-roller
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    i'm gonna guess it's the TRD kit because the URD kit doesn't need bigger injectors unless you get the MKII and that one needs a x-1 and a lot more stuff.......
    So to answer your questions....
    1. Bigger injectors from URD are not able to be controlled by the stock ecu so you will need a tuning system to control them.
    2. No you do not need an aftermarket intake for the TRD set up. The URD set up comes with everything you need to get it going.
    3. Good luck finding the TRD injectors.... they don't sell them separately so you will need to find someone who has upgraded there trd injectors to the 68lbs injectors.
    4. 91 or higher or you will get ping.
  4. Apr 16, 2011 at 12:00 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
  5. Apr 16, 2011 at 1:02 PM
    Heschke
    Arroyo Grande, CA
    Tacoma PreRunner
    Yes sorry it is a TRD supercharger. So I cant run URD injectors with just the stock ecu? What programmer/system do i need to run them? Does anyone know how much trd injectors from the dealer would be if they even have them? It also has a urd 2.8 pulley on it if that effects the size of injectors i need. thanks for all answers so far and finding the thread.
  6. Apr 16, 2011 at 2:41 PM
    xroller
    X-roller
    1 hp mod
    X1 but they are no longer available. (Control injectors)
    You may want to get in contact with gadget though and see if the MAPECU3 can handle those injectors once it is released. The MAPECU2 may not be able to handle that big of an injector safely so he doesn't recommend using that for the injectors he sells.
    The TRD Injectors will be fine I think even with the 2.8 pulley. You will have to get your ECU reflashed though. If you decide on not getting a tuning system for it.
  7. Apr 16, 2011 at 3:04 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Here's the part #'s for the injectors PTR24-3507.
  8. Apr 20, 2011 at 11:49 AM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    #1- You should be able to buy the injectors thru your dealer from TRD. TRD buy's the parts separately then packs them nicely in a box as an entire kit. If for some reason your local guy have no clue what you are talking about it ???? then call TRDparts 4u and they should be able to help you. I belive they sell the largest amount of superchargers on line.
    #2- Once you install the supercharger you will need to reflush your ecu at Toyota or if you can pay??? buy a APR box from URD. Is about $1100 or so.
    the guys are saying that this is the best , most efficient set up. The way your ecu is set up now,,, will not work. Will need to compensate for additional air and gas.
    #3- I had the 2.85 pulley installed after the supercharger was installed and I did not need a new reflush. . Based on my calculation,, the difference is about 6-7 %. and the ecu adjust tothe difference. Same as you would go form sea level to 12000' altitude.
    I hope this help and don't be afraid to install that baby by your self. The best satisfaction you will get after.
  9. Apr 26, 2011 at 11:58 PM
    Richdvc
    Richdvc Member
    Richard
    Tucson
    08 Sport 4x4
    3" ICON Lift AFE Cold Air Intake JBA Long tube headers Magnaflow Exhaust Urd 2.825 pulley Custom Rear HC bumper
    If you bought the Supercharger with the URD pulley with no injectors on ebay for $3000. Its the one i thought about buying too. I did my RESEARCH! and looked for injectors everywhere for what the seller said it should be $500 dollars BS. I called URD and Gadget said their injectors would not work as previous post have stated why. The only injectors that will work are the TRD ones that you can get from dealer. They are $190 bucks apeice for a grand total of $1200ish for dealer will also charge you to order them plus if you get them youll still have to take truck back to dealer for Flash of ECU after you install charger thats about a $100. I ended up buying one from TRDPart4u.com for $3600 with full warranty, had dealer install for $550 to keep truck warranty. So with that said I saved more money just buying new.
