Supercharger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jm3280, May 25, 2010.
  1. May 25, 2010 at 5:38 PM
    jm3280
    jm3280 [OP] Well-Known Member
    Jay
    Allentown, PA
    2010 TRD Off Road
    May be stupid, but whats up with the Supercharger people are doing to their trucks? Anyone have any good threads on this, price, installation, who installs this. Thanks
  2. May 25, 2010 at 5:39 PM
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
    if im not mistaken the trd website has them but im not sure if they sell them? this is probably a worthless post, but a free bump non-the-less
  3. May 25, 2010 at 5:52 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    I can give you a few things...although I'm n/a and saving up for my TRD S/C...there are some things to consider...
    currently there are 3 S/C kits made for the 1GR-FE motor...its the TRD S/C, URD MK1 and MK2 S/C...
    most people get the TRD S/C due to the fact that its a Toyota product and you can be covered under factory and extended warranty. If you install the S/C yourself I believe that the warranty is up to 15K miles and save you anywhere from $400-750 of cost for installation. If you get Toyota to install the S/C, they will warranty the s/c up to the remainder of your warranty...if your 30K warranty is up the s/c will be warrantied up to 15K but if you have extended warranty the s/c will remain covered under the warranty policy until it has expired...Another thing to keep in mind is that if Toyota installs the s/c they will have to flash your ECU to adjust timing and A/F Ratio for the larger injectors. Also keep in mind if you decide to sell your truck and part it out you will have to pay anywhere from 4K-5K for a new ECU because the ECU once flashed by toyota for the s/c CANNOT be flash back to stock.
    URD has the MK1 and MK2 kits out. The MK1 kit is solid but the MK2 is a whole other beast. I say that because the MK2 kit has 3 different stages and allows you to build up the s/c for more power. smaller pulleys, DTLH, URD competition Y-pipe, URD Exhaust, and a tune from Gadget will get you tons of HP...
    All 3 kits are awesome in their own way. Where as the TRD S/C makes gobs of torque because its a roots style s/c...the MK2 makes gobs up HP higher up in the power band range...it really comes down to what you want to use your truck for. High rates of speed like drag racing, auto cross, baja style driving I would suggest the MK2. If you do more off roading like rock crawling, trails, mud bogging, etc...I would choose the TRD S/C...
    another thing that's awesome is if you own a '05-'08 Tacoma with the 1GR-FE...there is a tuner unit called the APR X-1. This piggy back unit is so awesome that once you install the X-1 it will learn every performance part there after and adjust the tune by itself for optimum performance. of course you can hook your laptop up to the x-1 and run data logs. by doing data logs you can then send it to either APR, Gadget from URD, or any of the X-1 guru's around and they will help you diagnose the data and tune the map for even better performance. X-1 also turns your check engine light into a shift light cause it raises the redline from 5500 rpms to 6200 rpms. It even has a launch control for those who like drag racing but don't want to lose traction off the line. If you remember that I mentioned that Toyota reflashes ECU's for S/C applications...well if you have the x-1 installed to the ecu prior to getting a reflash...you can always reflash the x-1 back to stop settings if you ever decide to sell your truck and part it out to get some money for your next venture...
    APR also makes a 7th injector, E85 injectors (E85 octane is rated between 101-105...makes more power but less MPG), and they are in the works for a T56 transmission swap. The 7th and E85 injectors can be combined with the TRD S/C to make even more power if that's what your seeking. URD has a different setup from my understanding to gain more power.
    like i said before it really comes down to what you want to do with your truck...if you have any questions feel free to hit me up through pm's...good luck and keep us posted on your decision...either way you go...you pay to play...:D
  4. May 25, 2010 at 6:14 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Excellent post Tollphr33. I think you covered it well. Also, the TRD S/C has a number of nice add-ons for adidtional power. Both URD, APR, and NST have a number of pulleys to help you get more out of the blower. I would highly recommend getting the APR X1 kit. It makes a big difference and the engine guardian is worth the price alone.
  5. May 25, 2010 at 6:20 PM
    T0LLPHR33
    BSP TRD Off-Road
    don't forget that the x-1 also improves throttle response and for both n/a and s/c open up the engines potential greatly...
    IMHO the x-1 throttle response has improved the truck so much...that 2nd feels like 1st, 3rd feels like 2nd, and so on...:D
    sorry I kind of forgot to mention the URD, APR, and NST pulleys...but I didn't want to hog all the awesome info...lol
  6. May 25, 2010 at 6:20 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Being that you have a 2010 your only option is the TRD s/c with dealer reflash. X-1 won't work on the 09-10s.
  7. May 25, 2010 at 6:22 PM
    T0LLPHR33
    BSP TRD Off-Road
    good looking...I didn't even think to look at what year or type of tacoma he had...
    the 2010 ecu pin setup is different from the '05-'09s...because of this, toyota is the only 1 with the design and the only 1 making that type of pin configuration making it hard for companies like APR to make a X-1 or other tune computers compatible with the new ECU and pin configuration...
    once toyota releases the wiring I'm sure other companies including APR will make a X-1 Version 2 (X-2...:D) for the 2010 and dual VVT-I 1GR-FE motors...at least that's what we are all hoping...
  8. May 25, 2010 at 6:24 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I love my TRD SC and Im saving for a x-1 I think.
  9. May 25, 2010 at 7:26 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    It also looks great in the engine compartment.
  10. May 25, 2010 at 7:34 PM
    HomerTaco
    HomerTaco Chillin & Grillin Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    Fantastic reply post sir!
    I also plan to s/c later on this year. (had the gen 1 s/c in my 99' taco)
    lousy pic but here it is:
    +1 for you for a knowledgeable and well written post!
