Superior Overleaf Helper Springs 11-1030
Discussion in '1st Gen. Tacomas (1995-2004)' started by OldBoysToys, Jul 16, 2015.
  1. Jul 16, 2015 at 4:27 PM
    OldBoysToys
    OldBoysToys [OP] Active Member
    Jim
    1997 Black extracab tacoma - 2002 Imperila jade extracab TRD Tacoma
    Bilstien shocks toy tec lift Brush guard / Helwig 1250 Helpers
    Superior Overleaf Helper Springs 11-1030 anyone try these on their Tacoma. I'm looking for a cheap boost on my 2002 .I'm wondering if the rear spring clamp will be in the way .~~OBTs~~
  2. Jul 17, 2015 at 1:09 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Can`t help with those But I will say The Super Springs are one of the best things I have ever done to any vehicle.
  3. Jul 17, 2015 at 11:18 AM
    ELMO67
    ELMO67 Well-Known Member
    Ct.
    04 Tacoma 4wd reg. cab
    I have these on my '04 Tacoma reg. cab, 4wd. I have the nuts backed off as far as possible to keep the tension off for a softer ride and I'd guess at that setting they allow a 700 lb. load with the truck sitting level. The ride is stiffer even at this setting, but not too much more than stock. Now as far as the clamps, they do get in the way and prevent the overload springs from being placed really close to the axle, but they seem to be working out ok after 2 years. I use this truck as a daily driver and part time junk hauler, but I wish there was a full leaf pack I could replace this with that wouldn't give me too much lift or a rougher ride.
  4. Aug 14, 2015 at 10:59 AM
    OldBoysToys
    Jim
    I went for the Hellwig 1250 helper springs , a bit more money ,but worked out really well so far. Got about a 1 1/2" lift and they are cranked but half way. Can adjust independently so can off set the Tacoma tilt somewhat. Handles better ,rides a bit harder ,can feel the joints on our bad roads now, Not nearly as harsh as the AALs on my 97 taco. I wanted a firmer ride . Toyota lost there suspension when they went to the Tacoma . My old 87 Extra Cab was a real truck out the door . the 97 was a Yuppy mobile truck . needed some spine added to come close to the old one. ~~OBTs~~
