Superwhite's dcsb 38's build
Discussion in '2nd Gen. Builds (2005-2015)' started by superwhite, Feb 19, 2017.
  1. Feb 21, 2017 at 7:46 PM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    might copy your handbrake setup since ill be losing my ebrake as well, just sucks cause the spot where you mounted yours is where my transfer case shifters come up.
  2. Feb 21, 2017 at 8:56 PM
    superwhite
    superwhite [OP] Well-Known Member
    sean
    Western NC
    07 double cab 4x4
    Dana 60 rear Chevy 63's shackle flip mid travel gears lockers and 38's in progress
    There was room on the drivers side it was just at an angle and drove me crazy
  3. Feb 21, 2017 at 9:05 PM
    xweslingx
    Wes
    Durham, NC
    the hydro brake on my drift car was driver side actually. might try that..says you're in NC, where exactly? Im over in Durham
  4. Feb 21, 2017 at 9:13 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    In the asheville area not too far
  5. Feb 21, 2017 at 9:18 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
  6. Feb 21, 2017 at 9:42 PM
    xweslingx
    Wes
    Durham, NC
    Nice we'll have to go wheeling. @Mothman lives out here too. Come wheel with us sometime.
  7. Feb 21, 2017 at 9:44 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    I'm always down for some wheelin. With any luck I'll be done with the thing in a few weeks.
  8. Feb 21, 2017 at 10:20 PM
    xweslingx
    Wes
    Durham, NC
    april 1st uwharrie opens back up. might use it for a shake down run with my d60
  9. Feb 21, 2017 at 10:22 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
  10. Feb 22, 2017 at 4:19 AM
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    Subbing cause we gonna need to wheel. I'm in and out of Asheville pretty frequently
    superwhite[OP] and ChadsPride like this.
  11. Feb 22, 2017 at 4:43 AM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Are you going to shave your 60 for ground clearance?
    ChadsPride likes this.
  12. Feb 22, 2017 at 5:40 AM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Not at this time. The thought of cutting up a brand new housing freaks me out a bit.
  13. Feb 22, 2017 at 11:11 AM
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    So you are gonna roll 38"s on IFS? Man, that's pushing the envelop by quite a big margin.
    If I were you, I would bite the bullet and do a SAS. You already built a custom frame for the rear and have a d60 going under there. You are upgrading the brakes too. It is begging for a d60 in the front!
    Just :sawzall: the IFS off and put a straight axle under there and be done. Do it right, do it once!
    THROTTLE231 and ChadsPride like this.
  14. Feb 22, 2017 at 12:05 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    As much as I would love to, and know I'm capable, I refuse to start until I have all the parts. I was recently laid off so dropping 10-15k isn't exactly an option right now.
    It's mainly a daily for me with moderate wheeling trips, I really don't think I have to worry about breaking much.
    When I do start the front end it will be much simpler to do with all the extra. Crap out of the way.
    Mothman and ChadsPride like this.
  15. Feb 23, 2017 at 11:51 AM
    #35
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Famous last words :D [highlighted above]
    If you are in a situation in which you cannot pull a SAS off financially that's understandable.
    I just think that's way too big and heavy of a tire for IFS, even with moderate wheeling. I would be paranoid all the time! Not to mention the expenses of daily driving with big meats. Even with 35"s stuff starts wearing off fast with the IFS; ball joints, steering rack components, etc. It's really a lot of weight.
    Well i guess anything can survive if you drive/wheel carefully.
  16. Feb 23, 2017 at 6:20 PM
    #36
    xweslingx
    Wes
    Durham, NC
    I do agree with you on that SAS with a one ton is the way to go as I have a d60 going in, in a few weeks as well but I have to point out that the second gen front end can handle a hell of a lot of abuse. A lot of people on here wheel them on 37s all day without an issue. That said, they're not running the hammers either but still
  17. Feb 23, 2017 at 9:23 PM
    #37
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Didn't know there was "a lot" of people with 2nd gens on 37s.
    I have seen IFS carnage on 2nd gens with smaller tires than that. But everything is subjective because some people do drive/wheel like maniacs...in which case anything can break with any tire size :D
  18. Feb 24, 2017 at 6:41 AM
    #38
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Got the master and booster hooked up yesterday. Adapter plate and pushrod worked out perfect. All lines up the e brake plumbed and bled.
    Just have to seal up the passenger side wheel tub and throw some seam sealer on then it will be back on its wheels again. Hoping to get it started again within the next week or so.
    Robertocritser and ChadsPride like this.
  19. Feb 24, 2017 at 6:58 AM
    #39
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Sub'd hell yeah @superwhite truck is going to be a beast.
    ChadsPride and superwhite[OP] like this.
  20. Feb 27, 2017 at 3:44 PM
    #40
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Anybody have a spare nylon fuel supply line that goes to the fuel rail? I mistakenly cut the quick connect fitting off and need that part to connect to my AN fittings.
