SupraYota
Discussion in '2nd Gen. Builds (2005-2015)' started by LsuMeDesigner, Jan 23, 2013.
  1. Jan 30, 2013 at 4:29 AM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Kelson has a very nicely lowered single cab.
    http://www.tacomaworld.com/forum/2nd-gen-builds/17539-kelsons-reg-cab-30.html#post6356656
    As well, there will be some info thrown about in the Lowered B.S. thread.
    http://www.tacomaworld.com/forum/street-trucks/141305-lowered-b-s-thread.html
  2. Jan 30, 2013 at 10:33 AM
    #42
    LsuMeDesigner
    LsuMeDesigner [OP] Well-Known Member
    Thanks Torqspd
    Yeah he def has a good looking single cab. Im actually just scared to go that low. But his thread gives me a good idea on how to achieve the height im looking for.
    When i look at the body and suspension components of the truck i only want to lower like 2/2.5 but when I look at the GIANT gap between fender and wheel I want to lower it by like 3/4 lol
    I guess I will put the lowering kit on and see how it looks after and readjust my plan accordingly.
    Also ordered a shorty antena from Craven Speed today. Just a little touch to help with the "paw paw" look as my girlfriend calls it.
  3. Jan 30, 2013 at 10:35 AM
    #43
    LsuMeDesigner
    Also performancetruck.net is having a truck shootout on April 6th, it will be a hard deadline to meet, but Im using that date as motivation to have the truck ready.
    Torspd you gonna be out there? I know you are from texas.
  4. Jan 30, 2013 at 11:57 AM
    #44
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Paw paw :confused: Must be an inside joke. ;)
    Not sure if I will be there or not. First time I heard about it.
    Was really wanting to be ready for TX2K13. But at this rate, it doesn't look like mine will be up to full potential by mid March either..... :( My fingers are crossed though.
    Who knows, I might just be able to make that one you listed though.
    Yours is getting there Kase. :thumbsup:
  5. Jan 30, 2013 at 12:13 PM
    #45
    LsuMeDesigner
    Ha yeah paw paw...like grandpaw, not sure if thats just a Louisiana word. Lol
    Pretty much she just thinks its plain and something an old man would drive.
  6. Jan 30, 2013 at 12:17 PM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :facepalm: I feel like a dufus. Lol
  7. Jan 30, 2013 at 12:17 PM
    #47
    jbmccul
    jbmccul Well-Known Member
    2021 GMC Sierra AT4, 2019 Audi A5, 2017 Audi Q5
    You in Baton Rouge?
  8. Jan 30, 2013 at 1:59 PM
    #48
    LsuMeDesigner
  9. Feb 3, 2013 at 12:12 PM
    #49
    LsuMeDesigner
    Alright haven't been able to get much done, sorry for the lack of an update. I have the 8.8 rear axle cleaned up and ready to be paints black.
    The calipers are also semi-ready to be painted red.
    How do you guys suggest getting the calipers clean??
    These things were caked with brake dust/grease. I started out by just wiping them down with acetone and a brush. Then I took a wire wheel to the large portions. I just can't get the crevices by the rubber boots clean without damaging the rubber shrouds.
    I've been working on a friend of mine's truck the past week. He is trying to get it in trucking magazine. 2010 GMC 4door with 6.0 boosted with a 78mm turbo.
    I'll prob post some pics of it when I get home.
    Also wanted to hear everyone's opinions on pistons. I'm kinda just looking around for used GTE pistons, but I'm also considering going with forged low compression pistons from JE.
    So what are yalls thoughts on just swapping in JE pistons, new gaskets and ARP hardware? Would I need to rebalance the whole motor??
    If I'm swapping pistons should I also swap in rods and replace bearings while I'm at it??
  10. Feb 3, 2013 at 12:13 PM
    #50
    LsuMeDesigner
    Also small update, my drop kit came in Saturday, but I wasn't home to sign for it, so I guess I'll have to run to fed-ex sometime this week.
  11. Feb 3, 2013 at 12:16 PM
    #51
    poundin tacos
    poundin tacos Well-Known Member
    Scot
    Dallas, TX/ SFL
    2021 TRD Off-Road, 2018 built Macan Turbo (daily), 2nd gen dodge, 89 944
  12. Feb 3, 2013 at 12:22 PM
    #52
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    CP Pistons are my preference. If you are going to be installing pistons, then you might as well put rods in there two. If you are doing those, then definitely new bearings.
    If you do either or, have it rebalanced. Since you are boosting it, I suggest both. Rods and pistons. Definitely some upgraded head studs.
  13. Feb 3, 2013 at 1:01 PM
    #53
    jbmccul
    Awesome man, you should join up on Cajun Yotas
  14. Feb 3, 2013 at 1:26 PM
    #54
    LsuMeDesigner
    Yeah that's what I'm thinking Torspd.
    Can't hurt just to have the whole thing rebalanced.
    But then that brings up a new option. If Im going that far in the motor I might as well bore it slightly over.
    I also just purchased my turbo. Went with a precision ball bearing 6262 with .81ar.
    Got it from a friend for $350, has a blown seal but no shaft play.
    So I'll also be doing a small write up on rebuilding turbos.
  15. Feb 3, 2013 at 1:28 PM
    #55
    LsuMeDesigner
    Is Cajun Yota a club or forum?
  16. Feb 3, 2013 at 1:30 PM
    #56
    jbmccul
    It's a club, we're on Facebook
  17. Feb 3, 2013 at 1:59 PM
    #57
    LsuMeDesigner
    Okay I sent a request
  18. Feb 5, 2013 at 8:00 AM
    #58
    LsuMeDesigner
    Update time!!!
    Still haven't had time to pick up my drop kit from FedEx. :(
    Shout out to Craver Speed on the antena, I got the stubby model from them for $25 and they shipped it right out. Put it on the truck last night and it looks great.
    I plan on lowering the truck this weekend giving her a good wash and I'll post pics.
    Not a lot of work has been getting done because I been busy, but I have been ordering parts left and right.
    Kinda threw budget out the window this morning...
    Ordered JE forged pistons 8.5 compression, BC forged rods with ARP2000 fasteners, ACL race bearing kit, and arp head studs.
  19. Feb 5, 2013 at 8:07 AM
    #59
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Hell yeah. Got some goodies on the way!
  20. Feb 5, 2013 at 8:59 AM
    #60
    LsuMeDesigner
    Haha yeah man I'm excited!!
    This week long shipping is killing me though. Lol
