SURGING STOPPED AFTER WRECK
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deftoned_one, Nov 2, 2010.
  1. Nov 2, 2010 at 7:17 AM
    deftoned_one
    deftoned_one [OP] Active Member
    rich
    missouri
    07 PreRunner SR5
    K&N AIR FILTER,RUNNING BOARDS
    HEY GUYS JUST WANTED TO GIVE YOU GUYS SOME WIERD ADVICE, EVERYONE KNOWS ABOUT THE SURGE WHEN YOU ARE IN GEAR AND STOPPED LIKE AT A STOPLIGHT AND IT WANTS TO JUMP FORWARD. WELL HERE BOUT 3 WEEKS AGO I HIT A DEER IN THE RIGHT FRONT CORNER. IT DID NOT BLOW THE BAGS BUT IT DID ABOUT 6 GRAND WORTH OF DAMAGE. ANYWAYS, I NOTICED AFTER I GOT MY TRUCK BACK FROM THE BODY SHOP, THAT IT DOES NOT DO THIS SURGE ANYMORE. THEY DID NOTHING WITH MY BRAKE SYSTEM SO I DONT KNOW BUT IM NOT COMPLAINING. JUST WANTED TO LET YOU GUYS NOW
  2. Nov 2, 2010 at 7:18 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    OKAY GLAD TO KNOW, NOW I JUST NEED TO FIND A DEER.
    why are you yelling?
  3. Nov 2, 2010 at 7:21 AM
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    I noticed the surge all but dissapeared when I removed my sway bar, which is strange, because the consensus here is that it's caused by a slight amount of axle wrap in the rear...did you break a sway bar link?
  4. Nov 2, 2010 at 7:24 AM
    deftoned_one
    rich
    missouri
    07 PreRunner SR5
    NO I DIDNT BREAK ANYTHING SUSPENSION RELATED, AND IM NOT COMPLAINING, JUST LETTIN YA KNOW MAYBE ITS SOMETHING THAT CAN BE FIXED BY DIGGING INTO IT.
  5. Nov 2, 2010 at 7:25 AM
    deftoned_one
    rich
    missouri
    07 PreRunner SR5
    HERE IS ONE THING, RIGHT BEFORE I HIT THE DEER I DID SLAM ON MY BRAKES AND SKIDDED. YOU THINK MAYBE THAT HAD SOMETHING TO DO WITH IT, JUST A THOUGHT
  6. Nov 2, 2010 at 7:26 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    PLEASE STOP YELLING
  7. Nov 2, 2010 at 7:32 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  8. Nov 2, 2010 at 7:37 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    TURN YOUR CAPS OFF, And correct me if I'm wrong the surge was the a/c compressor kicking on. Maybe now your compressor is bad?
  9. Nov 2, 2010 at 7:40 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    x2... I wonder if during the accident the A/C system lost pressure. WHen it was fixed they didn't fix the A/C therefore stopping the surge.
  10. Nov 2, 2010 at 7:42 AM
    Falcon86
    Falcon86 Well-Known Member
    Virginia Beachshire
    Bone-stock
    I just want to add, on my first Tacoma, a '97, I noticed the "surge" big time when I had the A/C on. Here we are going into '11 and it's still going on.
    Makes me lol.
  11. Nov 2, 2010 at 10:27 AM
    deftoned_one
    rich
    missouri
    07 PreRunner SR5
    sorry for the caps guys, the salvage yard i work at, its how we have to have the keys. My ac works great so i dont know what is goin on
  12. Nov 2, 2010 at 10:34 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    x2 if its a long enough red light my truck will do it a few times...
  13. Nov 2, 2010 at 10:34 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    x2 if its
  14. Nov 2, 2010 at 10:39 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Did your leaf springs shift a bit as a result of the accident? Might want check your u-bolts and make sure their tight.
  15. Nov 2, 2010 at 10:50 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Weird, maybe something on the electrical side and your compressor is just always on, hence no surge.... I'm just guessing. Is there a way to check that, maybe someone else would know how?
