Surround Sound Help
Discussion in 'Music' started by Supra TT, Dec 26, 2011.
Thread Status:
Not open for further replies.
  1. Dec 26, 2011 at 6:41 PM
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    I currenty have the samsung HT-550 5.1 DVD digital home entertainment system..
    MY DILEMA......
    I am trying to connect the surround sound to the stupid TV so I can have surround sound to the dumb XBOX 360.
    A. I want to use HDMI on the xbox from the TV.
    As right now...
    Xbox360 HDMI - TV HDMI 1 port
    Samsung Receiver HDMI - TV HDMI 2 port
    No sound anywhere
    Fuck tvs and home electrical I only know wind turbines :(
    Help :D
  2. Dec 26, 2011 at 6:44 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    did you turn off the "internal mute" on the tv? that should fix it if you plugged it all in right. that's the way mine is.
  3. Dec 26, 2011 at 6:47 PM
    MHS2846bg8
    MHS2846bg8 Experienced Noob
    Nate
    South Coast of Oregon
    21 Tacoma TRD Off-Road Dbl Cab 4x4
    4WP Factory Front Bumper w/Warn VR EVO 10-S Winch, AuxBeam 8-Switch Controller, Redarc Trailer Brake Controller, ARE CX-Evolve Cap, Bedrug Liner, Ditch Pod Lights, Aftermarket LED (OEM) Bed Lights, Console Vault
    right now I have HDMI from my xbox to my TV...then RCA from TV to Receiver. Seems to work fine. I don't usually bother with HDMI to a receiver
  4. Dec 26, 2011 at 6:50 PM
    jgwheeler17
    NC
    neglect, mostly.
    and OP remember that the sound isn't gonna be any better with hdmi apposed to high def cables. you've probably got a hundred ports for those which leaves you more options as apposed to just hdmi.
  5. Dec 26, 2011 at 7:02 PM
    Supra TT
    Eric
    Indiana
    Well I currently have no component cables at the house, and like 4 hdmi cables so I figured that would work. Are you trying to say I need to get component cables? white yellow red?
    Also the receiver has numerous function settings.. like aux 1/2 d. In. dvd, ipod, etc..Which function is it suppose to be on..
  6. Dec 26, 2011 at 7:03 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Can't you go hdmi from the Xbox into the receiver ? That's how my PS3 is hooked up .
  7. Dec 26, 2011 at 7:04 PM
    Supra TT
    Eric
    Indiana
    I have the hdmi cord from the receiver to the tv currently
  8. Dec 26, 2011 at 7:06 PM
    OZ-T
    Peter North
    British Columbia
    I editted my post .
    Hdmi from the xbox to the receiver then hdmi from the receiver to the tv
    My ps3 is hooked up that way
  9. Dec 26, 2011 at 7:06 PM
    OZ-T
    Peter North
    British Columbia
    This ^^
  10. Dec 26, 2011 at 7:08 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    digital is always better than any component cable if that is what you are referring to as high def cables. As posted earlier everything needs to go through the receiver. You need to use the receiver as a switch between components.
    So you will want to run an HDMI from your xbox to an HDMI input on your receiver. Pick which one you want to use for your xbox. My receiver has "game" input and that is what I use for my computer. If you have a cable box use an input for the cable box. Use the HDMI output on your receiver to connect to your TV.
  11. Dec 26, 2011 at 7:11 PM
    Supra TT
    Eric
    Indiana
    Only 1 port for HDMi in the back on the reciever
  12. Dec 26, 2011 at 7:15 PM
    OZ-T
    Peter North
    British Columbia
    Your surround sound receiver only has one hdmi in port ?
  13. Dec 26, 2011 at 7:15 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    If you plug everything into the receiver then receiver to TV, then you always have to turn the receiver on, and that is not always wanted.
    Here is what I did.
    I connected everything to the HDMI ports of the TV. IE. Xbox, Blu Ray, etc.
    Then I connected the TV from the Audio Out port to the receiver.
    Works perfect for me. Should be the same for you. Depending on the TV, you might have to go to the TV options and select Sound Output, Out or something like that, but it should work. Then, if you do not want to use the receiver for whatever, you select TV speakers again.
    You will need to 2 RCA or whatever they are named cables or that. The red and white ones.
  14. Dec 26, 2011 at 7:17 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Your receiver only has an hdmi output? No HDMI inputs? That doesnt make sense. But if you cant go xbox->receiver->Tv then you will have to go xbox->TV then get another cable (component or optical) to go from the tv's sound output into the receiver sound input.
    Otherwise you cant use the receiver for sound from the xbox, only tv speakers.
  15. Dec 26, 2011 at 7:22 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Yeah I read the samsung site. You dont really have a "receiver" so the only way to have anything play anything using the surround sound (besides the built in DVD) is to use an optical audio out from your tv to the audio input the the HT-550
    Best place to get them is monoprice.com. Quality stuff and cheap
    That or you can get a real receiver with inputs and just use that HT-550 as a DVD player.
  16. Dec 26, 2011 at 7:22 PM
    Supra TT
    Eric
    Indiana
    Yeah I have an optical cable, no optical output in the tv though......... Sigh. Guess I'm getting some component cables
    Cool story bro?
  17. Dec 26, 2011 at 7:28 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Is there an optical out on the xbox? You should be able to go: xbox hdmi->tv for video and xbox optical->receiver for audio.
    I would imagine to set them seperate is in the xbox settings menu but I dont have an xbox to check.
    Then read the manual on the revceiver to check what it has to be on for audio input
  18. Dec 26, 2011 at 7:30 PM
    I Liquid I
    Puerto Rico
    Morning?
    I have a decent surround system, and I pretty much only want it for movies and games and music and concerts. Apart from that, the TV speakers are fine for regular programming that does not need decent sound.
  19. Dec 26, 2011 at 7:33 PM
    OZ-T
    Peter North
    British Columbia
    This confuses me too , why would you wanna watch HD channels that broadcast in 5.1 without your system on ?
  20. Dec 26, 2011 at 7:36 PM
    I Liquid I
    Puerto Rico
    I guess it is because I usually do not watch regular TV too loud, so I would not really benefit from the quality. Also, I said morning because I wake sometimes get up for work at like 4AM and like peace at that time, so TV tends to be low.
Thread Status:
