suspension? “mid-travel”
Discussion in '1st Gen. Tacomas (1995-2004)' started by __desert.taco, Jan 9, 2020.
  1. Jan 9, 2020 at 11:44 PM
    __desert.taco
    __desert.taco [OP] Member
    modesto CA
    2000 tacoma prerunner V6
    was wondering if anyone has purchased the rear shock hoops from solomotorsports and is so what rear shocks they paired with it?!
    as well as what deavers some are using pared with a spring under kit
    or any other “mid travel” rear suspensions set up you have that you would like to share....kind of looking for ideas. thanks!
  2. Jan 10, 2020 at 4:46 PM
    Kwikvette
    Kwikvette Chief Executive Officer at Kwik Fab
    Stock
    I see you posted another thread asking about spring under; maybe just keep 1 thread lol
    Unless you need some real flex, a lot of people wheel with aftermarket shocks in the stock location.
    If you want to use longer shocks though, just do a rear shock relocation via cross member between the frame.
    You're referring to an outboard setup, which isn't as common (but still used). Should net you different "handling" as I've read compared to having the shocks under the bed.
    Your IFS setup will need a lot of help to keep up with the front at this point.
    There are a ton of threads that share much more information than the little I've shared.
  3. Jan 10, 2020 at 5:02 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Deavers and a spring under kit?!
    The Deavers give you ~1.5" lift over stock, and if you try to wedge a spring under in there, you're going to end up lowering your truck. Don't bother with spring under unless you are building a race spec pre-runner, and I certainly wouldn't do J59's.
    The outboard shocks are hard to do for first gens. Our wheels are too close to the frame, so unless you get wheel spacers, they're going to rub like mad.
    As @Kwikvette said, most end up doing some sort of crossmember and a shock relocation. You can end up fitting I think a 10" or so travel shock without cutting the bed if you do the crossmember and doing a custom lower shock mount on the axle (also doing a U-bolt flip).
    Here's a good writeup as an example.
    https://adventuretaco.com/tacoma-rear-shock-relocation-scrapping-the-first-attempt-and-trying-again/
