Suspension / body Knocking sound on cold days
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Negative1, Dec 11, 2009.
  1. Dec 11, 2009 at 5:41 PM
    Negative1
    Negative1 [OP] Well-Known Member
    This is my first winter with this truck, 09 TRD 4x4 O/R
    The past couple of days it's been -5 to -9 degrees, and the truck has new, yet abnormal sounds coming from the front end when I go over bumps. At first I thought, maybe the shocks need time to warm up from friction.... But It sounds like the cab mount on the passenger side..
    Picture this if you will...
    Going over a bump, like a slightly counter sunken in manhole.... as the tire sinks into the depression in the road, the cab sinks with it, just a split second later, and then as the tire comes out from the hole, the cab comes up just a split second later... Causing a " "knock...."knock" sound..
    Thats the best I can explain it.... Wondering if anyone has experienced anything remotely similar...
    Another thing, slightly unrelated, but my steering wheel makes noise as I turn it when she's really cold.. kind of like something rubbing..
    Not worried about that so much though...
    Thoughts? :confused:
  2. Dec 11, 2009 at 5:55 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you need to park your baby in the house if its -5 to -9 degrees,crap thats cold dude.where you live?
  3. Dec 11, 2009 at 6:04 PM
    Negative1
    LOL...
    I should have mentioned Celcius.. I'm up north in Canada bro.. :)
    For you, that would be about 20F
  4. Dec 11, 2009 at 6:12 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I'm not real sure what it is, but I just noticed my old 4runner making a similar noise. It also only just started doing it with temps in the teens.:confused:
  5. Dec 11, 2009 at 6:17 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    down in alabama thats about as cold as it gets,and i'm glad cause i hate cold weather.mine is a 09 dc 4x4 and i have never heard mine do what you are talking about,could be a body mount i guess,does it quit when its warm?
  6. Dec 11, 2009 at 6:17 PM
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    I have a 95 extended cab and that is exactly what it did during the cold winters I drove it in Kansas. (I was stationed there) You may also get a god awful noise like some thing is really scraping against the entire vehicle...that will be your speedometer...it scared the shit out of me...but you may expect that if the speed-0 are cable driven in your vehicle.
  7. Dec 12, 2009 at 4:17 PM
    Negative1
    Yep, only does it when its cold out.... I'm puzzled...
    Could it be the shocks are stiff and need alot of movement to ''warm up'' ?
    I might take her into the dealer when I get a chance... Just hard to replicate unless its cold out.
  8. Dec 12, 2009 at 6:35 PM
    rme
    Savannah
    Green TACOMA
    Midas put mine on a lift and couldn't find it and when I took it in to the dealer in topeka he couldn't find it either.....good luck
  9. Dec 12, 2009 at 6:39 PM
    dlthunder
    dlthunder Well-Known Member
    Dan
    Reno, NV
    Sold my Taco
    TRD Skid Plate Rear Seat 11inch DVD Toyota Bed Mat Pace Edwards Full Metal Jackrabbit Nerf Bars Tailgate Electric Dynolock D-ring Bedbolts
    It has been -8F here the last week and my was making the same noise, once the truck warmed up it seemed to go away.
  10. Dec 12, 2009 at 6:58 PM
    Negative1
    Ok, so I'm clearly not the only one with this issue...
    I'll follow up with the dealer within the next week or two and come back and update this post with their findings if any...
  11. Dec 12, 2009 at 9:22 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Are you sure it isn't ice or frozen snow in your wheel wells? I get this allot in the winter months. Don't hear a thing until the suspension cycles.
  12. Dec 12, 2009 at 9:45 PM
    goride
    goride Well-Known Member
    Josh
    UTAH
    22 4dr lb white off-road
    Tint, sliders, puddle pods, on my way to more….
    Kinda funny my 09 did this the other day, it was about 18 or 20 degrees where I live.Only my noise was coming from the drivers side, sound like it was a similar sound. Dont know what it is,looked under dash, looked for ice chunks.looked for anything,it has since stopped.Called dealer so they are aware.Let us know if you figure it out.
  13. Jan 11, 2010 at 10:58 PM
    Pyrite FD
    Pyrite FD Well-Known Member
    Indiana
    09 DC TRD Off Road
    lol...mine is doing it too. makes a clunking noise from the front left. i can feel it through the floor on in the area to the left of the brake peddle. its around 20F here. gonna bring it in a heated garage and wash it and remove any ice and start wiggling things around.
  14. Jan 12, 2010 at 4:50 AM
    Negative1
    I should have come back to respond to this thread..
    It ended up being snow/ice buildup in the inner wheel wells on both sides.
    I still haven't washed it though.... But I know thats what the problem is...
    Nothing to worry about, just annoying...
    Ps. I dont have mudflaps, which may be the reason for this.
  15. Jan 12, 2010 at 6:24 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    WOW...I was going to come in to work today and start the exact same thread. I have a loud knocking noise right under my feet on the drivers side. It sounds like something is loose in the suspension but everything seems to be working properly.
    I also assume it is snow/ice buildup and need to get my truck warmed up to know for sure. I hope I don't have to wait until March to find out....
    I do not have front mud flaps either.
  16. Jan 12, 2010 at 9:16 PM
    Pyrite FD
    Indiana
    09 DC TRD Off Road
    haha nice. ya i came here tonight to post about how i brought it in the heated bays and washed it and let it sit for a few hours to melt anything else. i saw a lot of ice in crap through the cracks. i also have no mudflaps.
    lots of small chunks of ice were in there though.
    drove it home and silent again.
  17. Jan 21, 2017 at 3:02 PM
    AkArin
    AkArin Well-Known Member
    08 TRD Off-Road
    This is literally what I am experiencing. Front, driver side, knocking sound under my left foot from wheel well area, seems like something is loose, but everything looks fine. Haven't experienced it before winter. I live in Anchorage, AK so there's plenty of snow/ice. I don't park in a garage so I can't thaw anything out and see if it goes away. Has anyone solved this mysterious phenomenon? It sounds terrible.
  18. Jan 21, 2017 at 3:16 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    I had that happen when the truck was still new (it's an '05). I used to get a knocking sound when going over over brake bumps, or washboard type of surfaces. It only happened when it was below 40 degrees outside. It ended up being the body mount bushings. At the time there was a TSB for this, so the dealership replaced them, and I haven't heard it since.
    AkArin[QUOTED] likes this.
  19. Jan 21, 2017 at 3:40 PM
    AkArin
    08 TRD Off-Road
    Thank you for the input. Hmm, is it something worth checking out myself to correct/replace or should should I pay the dealer/shop to do it? Sounds like if there was a TSB for it in the past and my truck is still doing it then the dealership should take responsibility.
  20. Jan 21, 2017 at 3:46 PM
    DrFunker
    DrFunker Well-Known Member
    Happens to mine too. :anonymous:
