Suspension help
Discussion in '1st Gen. Tacomas (1995-2004)' started by DigB, May 13, 2010.
  1. May 13, 2010 at 12:51 PM
    DigB
    DigB [OP] Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Hey,
    I just upgraded my tires on my '03 Tacoma, I went from Wrangler Silent Armor 265 70R 16's to Wrangler DuraTrac 265 75R 16's I was under the impression that I wouldn't have any rubbing issues, I went to test them out and I rub when I turn Left. I'm rubbing on the rear of the fender well on the Driver side basically on the mud flap and the plastic just above the flap. I also rub on the frame on both sides when I turn either direction but only when I'm at full lock but the amount is very minor.
    I am looking for some solutions to the rubbing. I've tried trimming the plastic above the mudflap but there is still some contact when I'm going over rougher terrain.
    Would more intense trimming fix it, by looking at it I doubt it, or should I look at a lift and/or spacers?? I'm fairly new to this so pardon the newb questions but any help would be appreciated. I'm also not made of money so if I could do it for less than 4 or $500 that would be nice.
  2. May 13, 2010 at 12:57 PM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
  3. May 13, 2010 at 1:13 PM
    DigB
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    The link doesn't work
  4. May 13, 2010 at 1:43 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    youll need to do the pinch weld mod and probably put on some 1/4 wheel spacers(10$ a piece) to fully clear everything
  5. May 13, 2010 at 1:54 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
  6. May 13, 2010 at 2:06 PM
    DigB
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Thanks for the link, I think that will be my next mod, I'm hoping to keep everything stock height if possible, Time to dig out the hammer!!
  7. May 13, 2010 at 2:11 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    your welcome
