Suspension Issue *Please Help*
Discussion in 'Suspension' started by TacoMTVT, May 21, 2024.
  1. May 21, 2024 at 6:10 AM
    TacoMTVT
    TacoMTVT [OP] Member
    2015 White Tacoma Limited
    Good morning all,
    Here's my situation: I have a completely stock 2015 Tacoma, Limited, 6' bed. I have Michelin LTX's with about 40K on them and plenty of tread life. Two weeks ago, I replaced the rear shocks and front assembled coilovers with Bilstein 4600's as well as the front sway bar end links.
    Bilstein 4600 Assembled Coilovers with OE Replacement Springs and Rear Shocks for 2005-2015 Toyota Tacoma (suspensionlifts.com)
    Everything was tightened to spec upon re-assembly. I did not get a front-end alignment after project completion. While driving, between 35-45mph only, there is a strange, unbalanced noise in the front end (whomp . . . whomp . . . whomp). It almost feels that the tires are warped, or something is rubbing. The steering has no vibration and does not pull so I don't think an alignment is needed. Has anyone experienced this? I have set up an appointment with a Toyota dealer this Thursday and while talking to the tech on the phone, he asked if I had shifted into 4WD high and low recently. I did, and the noise persists. For an otherwise impeccable truck, this is annoying! I would be grateful for any troubleshooting advice.
  2. May 22, 2024 at 12:22 PM
    PETEREDGE
    PETEREDGE Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,YOKAHAMA MT'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
    Anytime you change front shocks you need an alignment.
  3. May 22, 2024 at 3:51 PM
    TacoMTVT
    Thank you for that, I have had conflicting advice on that topic, but hoping that I just need an alignment. At the dealer now, so I’ll know more tomorrow.
  4. May 23, 2024 at 1:32 PM
    TacoMTVT
    **Update**
    Toyota dealer says the problem is the right front wheel bearing. Replacement of right front wheel bearing + alignment = $1,500.:eek:
  5. May 23, 2024 at 1:41 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Unit bearing is like $300 and an hour of work. Alignment is $80. Find an independent shop. Try and get a good unit bearing though. Japanese bearing if you can.
  6. May 23, 2024 at 2:21 PM
    TacoMTVT
    I am thinking I will order a Toyota OEM wheel bearing (Koyo) and do this myself. A little surprised that I had one wheel bearing go bad after only 97K miles. The truck has never been off-road . . .
  7. May 23, 2024 at 2:28 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    SR-71A and ZColorado like this.
  8. May 23, 2024 at 4:44 PM
    ZColorado
    13 DCSB OR 6MT
    See the post above, definitely do that instead. Toyota does not sell the entire assembly.
  9. May 24, 2024 at 8:04 AM
    TacoMTVT
    Thanks again for all of the comments, advice; it is appreciated. I have reached out to 05Taco . . .
    Does it make sense to replace both front wheel bearings? Or should I just replace the front right (the one that is going bad)?
  10. May 24, 2024 at 8:10 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    As habit I like to install everything in pairs, unless I know the exact cause of a bad bearing. Whatever happened to the left side, chances are the right side drove through it too.
  11. May 24, 2024 at 8:22 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Change both
    ToyoTaco25 and SR-71A like this.
  12. May 24, 2024 at 8:28 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yes, echoing the above. Replace both with a set from the guy linked above. 100k miles for front bearings is not unheard of on these trucks
  13. May 24, 2024 at 8:32 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Get oem parts, change both sides together and do it a good indy shop. $1K+ for 1 side is nuts.
    TacoMTVT[OP] likes this.
  14. May 24, 2024 at 10:17 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    I have had good luck with the AC Delco Gold bearings that are already installed in a hub for about $170. It only takes about an hour to change it out. You also don't need an alignment for it, but def need one for new shocks.
  15. Jun 11, 2024 at 11:48 AM
    TacoMTVT
    Update: Finally got my truck into a reputable shop to replace both front wheel bearings (which I provided from 05Taco). The problem ended up not being the wheel bearings, but the needle bearing. Had I known more about the needle bearing issue, I would have read this thread, which described my problem to a "T".
    Needle Bearing - Yes, Replace It (ECGS) | Tacoma World
    Anyhow, I have two brand new wheel bearings that I'll be looking to sell.
    Steves104x4 likes this.
